Mine have been of two types both had a tab at the right side and either a tiny white button with a slot to turn it or similar that you had to slide, the sliding ones were better.
Sounds like Dometic both times?Mine have been of two types both had a tab at the right side and either a tiny white button with a slot to turn it or similar that you had to slide, the sliding ones were better.
yes your right you need to keep the sun off the grill's because the idea of the fan's are to take the heat away from the back of the fridge & if you are parked with the sun on the grills the fans are just sucking in more hot air which defeats the object . that's why you have to put the fan's at the top grill's & the main problem with most leisure fridges & cool boxes is they are only suppose to be 16deg lower than the outside of the fridge .which i speaking from experience having left the winter grill covers on & for got to take them off so went on our first trip from from storage the fridge had been on for about 3 hours when i went in the fridge to check everything was ok & it was no colder so i thought the fridge was knickered on going outside to check burner was alight noticed the covers was still on & the top cover was about to melt took them off & the fridge started to cool . so that's what got me in to putting top fans in having heat trapped at the small area behind the fridge is a no good .cheyenneI have a three speed computer fan installed on the the exhaust side of my Electrolux absorption fridge set up. But on a recent 4 week trip to the Netherlands, with ambient around 32 degrees cent, found fridge temps of 7 to10 degrees, especially if sun on rear of van of an afternoon.
So adopted the Heath Robinson approach of tie-wrapping the bike rack warning sign to the rear ladder to keep direct sun off the fridge area, and was happy to see the fridge temperature drop back to 3 degrees.
Same here ....I am only pleased I fitted a compressor fridge freezer over 10 years ago and not done anything since .
Got it in one lolSame here ....
Removed the temperamental 3 way absorbtion one and replaced with a domestic 240v undercounter one ...
Result is a no pfaff painless fridge that runs 24/7 through summer without even thinking about ...
No fans when it's warm
No concern about levelling
No sooty flues
No blocked burner jets
No wind in wrong direction
Etc etc
yes , but .... just think how quiet forums would be if everyone did thatI am only pleased I fitted a compressor fridge freezer over 10 years ago and not done anything since .
Vert true lolyes , but .... just think how quiet forums would be if everyone did thatthe 3-Way Fridge users keep the web alive with all their trials and tribulations
EXCLUSIVE! In this month's edition, we ask 'Which is better? AES or compressor fridge?' Police to undertake Cold Case Review ...I am just pleased I haven't t one David .
hi. the wire i used was super thin & the first thing we did was the wife poured water in the drain shelf & i was outside watching no problem otherwise i wouldn't have carried on with the job . as regards the comments about fridges a bit childish if you ask me but people with old knackered m/h's/campers & self build's like mine with a 3 way fridge it might do them some good but you cant please everybody all the time .cheyenneMake sure that the drain hole isn't blocked and it should be okay.
