Trotter
Great idea Eric. When can you design and fit it for me.Why don’t you fit a calorifier to heat your water.?
Bloody Engineers
my mate has done that eric to his VW T6Why don’t you fit a calorifier to heat your water.?
You psd the bedmy mate has done that eric to his VW T6
I used to have a van with a calorific. It was imported from Australia, where that made sense, driving huge distances. But I rarely drive for much more than an hour or two at a time, and often stay in one area for several days, so it was pretty useless. The gas multipoint water heater was excellent though.Why don’t you fit a calorifier to heat your water.?
Going way off topic.I used to have a van with a calorific. It was imported from Australia, where that made sense, driving huge distances. But I rarely drive for much more than an hour or two at a time, and often stay in one area for several days, so it was pretty useless. The gas multipoint water heater was excellent though.
Stop moaning ya grumpy auld git. I have only had 2 x 100Ah lifepo4 the last 5 years and manage ok. Mind you, I only have coffee machine, air fryer, induction hob, remoska, slow cooker (I think) I just don't use them unless the sun is out.I had a couple of weeks in Somerset, Minehead mainly. The weather was okay, until the storm anyway. Little sun, so no solar. It was this trip that convinced me that I had to keep the LPG.
Believe me, I detest the stuff. Heating the van on diesel, doable. In winter, heating water for a shower? Cooking? Forget it. Even with my Victron Orion 50, I’d have to run the engine for a couple of hours every day, just to try and keep up.
Now if it wasn’t for the Schengen nonsense , I’d be fine in winter.
So really, it’s because of Brexit, I have to keep LPG
Edit. I only have a tiny Fogstar battery. Well under 560ah. I could find room for a second.![]()
That's good to know Neil.Stop moaning ya grumpy auld git. I have only had 2 x 100Ah lifepo4 the last 5 years and manage ok. Mind you, I only have coffee machine, air fryer, induction hob, remoska, slow cooker (I think) I just don't use them unless the sun is out.
No worries about running out of gas in the future, Calor already do Bio-Gas which goes straight into your system with absolutely no changes needed if set up for propane/lpg
Less of the grumpy.Stop moaning ya grumpy auld git. I have only had 2 x 100Ah lifepo4 the last 5 years and manage ok. Mind you, I only have coffee machine, air fryer, induction hob, remoska, slow cooker (I think) I just don't use them unless the sun is out.
Bloody expensive Caz lololYou could get a diesel cooker and water heater if you really wanted to ditch the gas.
Gas is fine lolNo I’m stuck with gas. There’s a downside to everything.
electric fridge repair shop of course you silly bearIt's been good enough for most people for a very long time, most issues are easily fixed, where do you get an electric fridge fixed?
'fur enough', replied the silly bear ...electric fridge repair shop of course you silly bear![]()
Never seen oneelectric fridge repair shop of course you silly bear![]()
Cos they don't break down prapsNever seen one
