If care is taken when removing it there shouldn't be a problem, they do become brittle with age but the trick is to do it gently and evenly not putting stress in one area.
Baz, my original is still going strong. It has the wind up but you can also push up either side on barsYou are lucky it's dometic, heki , remis wind up mechanisms break regularly .
NEIL my van has had 2 replacement wind up mechanism and one replacement full skylight due to wind up locking failure , Remis 2 .Shhhh
Not certain but I think they may be similar operation when discussed in the past Baz. Mine has been in since the van was built so it’s 15 years nowNEILL my van has had 2 replacement wind up mechanism and one replacement full skylight due to wind up locking failure , Remis .
Mine has no bars just the crank .another remis problem is the rubber seal degrades and sticks to the skylight tried lubricants but still sticks after being closed for for a few month's, new seals are availableNot certain but I think they may be similar operation when discussed in the past Baz. Mine has been in since the van was built so it’s 15 years now
Oh dear , when I was looking I found some tilt and slide roof lights in scrap yards , I think you need to find the hole size and search for something that may fit , the last resort is to have the hole enlarged and to fit somthing like a heki .their s a company that re makes plastic windows perhaps they could repair a roof light , if so the roof light will have to be removed and sent on , several weeks turn round time ,,Eeco window repairs got to he worth a go . BazzMIne is a Remi slide and tilt, can't get one anywhere, and nothing else is the right size. Meanwhile the last lot of temporary repairs (gaffa tape) have started to leak again.
Mine too, anther use for a tiny smear of Vaseline.Mine has no bars just the crank .another remis problem is the rubber seal degrades and sticks to the skylight tried lubricants but still sticks after being closed for for a few month's, new seals are available
If it's the dome that's the problem, it should be possible to find some helpful person to remove it and then make things weathertight. When I removed a window to send to Eeco (which turned out to be a waste of time), I covered the hole with varnished plywood through-bolted onto timber struts placed across the window frame on the inside.Thanks Baz, I'll try again, last time I looked there was one and it had a big hole in it. I've emailed various places and been told no, and "you'll be lucky, they don't make them anymore".
I'm told there isn't enough room on the roof to make hole bigger and fit a Heki.
I know Eeco may be a possibility but I can't take the darn thing off and nowhere under cover to park it while it's copied.
I currently have two local firms who are supposed to be thinking of solutions for me.
It shouldn’t be a write off looking at the photos it’s exactly the same as mine a bog standard dometic heki midi my Motorhome repair guy ordered mine on the Monday it was delivered on the Wednesday and fitted on the Thursday the roof filler bits and Friday the actual skylight I’ll take photos in the morning.Mine had a huge hole and was leaking badly coverd roof light with plastic sheet and gorilla tape not a drop of water came in , I did consider removing skylight and temporarily fitting a polycarbonate sheet ,waiting time for a new skylight over 14 weeks , pay on order no delivery date final ,bill £800 .Caz Have you considered bonding a clear perspex sheet over outside of the damaged area using sikaflex and covering edge's with gorilla tape ??? , I contacted autosleeper for advice , have contacted Adria .if you had gone insurance and parts not available your van could be a right off ..Bazz
