Admin
Administrator
Yes, it can, but it fails because of the sensor fault. If I clear the fault it starts to regenerate then the sensor error gets logged and it fails. I did this 30 times and managed to get the clogging from 68% down to 40% so it is doing a 1% regeneration each time. I can drive the van now, but it has little power due to the back pressure. Hopefully, once the sensor is changed it will complete the forced regeneration.hi
you might be able to do a forced re-generation with that software.
