Iāll remove from MH and repair, just in case earth return lead screws up MH electrics.
A bit late now but I looked into welding on vehicles a few years ago and basically depending what you're doing there is no need to isolate at all, and for that bumper, it could have stayed on the reason being electricity will take the very shortest path so long as it has a good earth point for the clamp then it will not go any further, having said that if it's easy to remove then it's easier to work at a batter height and you can position the weld run better plus give it a good clean up prior to repainting.Been washing MH and got a better look at my metal bending skills, looks like 22.5 degree to me
The person responsible for coating the fish at our chippie works at a batter height ...A bit late now but I looked into welding on vehicles a few years ago and basically depending what you're doing there is no need to isolate at all, and for that bumper, it could have stayed on the reason being electricity will take the very shortest path so long as it has a good earth point for the clamp then it will not go any further, having said that if it's easy to remove then it's easier to work at a batter height and you can position the weld run better plus give it a good clean up prior to repainting.
Many year ago I bought a Mariner short shaft outboard for my RHIB, I got it for not a lot of money in real terms, due to a large chunk of the port side anti-cavitation plate broken due to a mishap I guess, and outboard housing are cast alloy. I did make a big fuss about repair cost to employ a welder.A bit late now but I looked into welding on vehicles a few years ago and basically depending what you're doing there is no need to isolate at all, and for that bumper, it could have stayed on the reason being electricity will take the very shortest path so long as it has a good earth point for the clamp then it will not go any further, having said that if it's easy to remove then it's easier to work at a batter height and you can position the weld run better plus give it a good clean up prior to repainting.
Tony, make sure you are wearing sunglasses when viewing the paintwork, without them you will be blinded!In a couple of weeks time Sue and I are off to Penwortham again to do a bit of gardening for Sueās dad - be warned Graham (Wooie) weāll be just round the corner from you. On the way back if our daughter will allow us weāre planning on staying over in Penicuik so that we can go to the Great British Food Festival in Dalkeith Country Park (as well as seeing daughter!) on 10th or 11th September. So be warned Terry (Runnach) I may well be peering (NOT peeing) over the wall to look at that bumper welding and paintwork job!!
PS went for the Hyundai 40v āstealthā chainsaw because it has a more powerful motor but mainly because I can get a spare battery!
Gerroff and stay off.The person responsible for coating the fish at our chippie works at a batter height ...
So easy to take the box of LOL.Many year ago I bought a Mariner short shaft outboard for my RHIB, I got it for not a lot of money in real terms, due to a large chunk of the port side anti-cavitation plate broken due to a mishap I guess, and outboard housing are cast alloy. I did make a big fuss about repair cost to employ a welder.
Engine purchased for much cheapness, I took it to work to repair. Earth return clamped close the repair area, I arced up (TIG) when I finished the tack, I nearly died with the reek within my welding bay. the various cables that were protected with a plastic coating, same as bike cables, the plastic melted. All due to the earth return lead. To separate the bottom part of the engine would be a pain, gearbox etc down there.
Engine worked fine and served me well for many years, no damage other than melted plastic, so with this experience, I always err on the safe side, hence rear guard removal, which was actually for the best, as the welding was not very good, it is now, though!
en.wikipedia.org
Wondered why I felt so at home in a dinghy ...So easy to take the box of LOL.
What on earth is a rhib, I know about ribs and inflatable dingies but that has me stumped.
Dingies use short shaft and ribs a long.
