Mtbcol
Thank you Pudsey. Very useful infoYou will of course have sills on the cab but any Fiat after 2001 I think has a zinc batch at the factory to help prevent rust, Mercedes are prone to rust regardless.
If going Fiat Citroen or Peugeot get post 07 as they are the best ones to drive, and of course parts are better to get too.
Thanks Nabsim, again great info and pics. Looks like the layout we want, but as said, might be hard to find in a shorter length vehicle. Could be a compromise thing again, and find bigger wild camp spotsMine is a C class, low line (no overcab bed). It was a Sprinter chassis/cab when it left the factory but is what Kev refers to as a cowl, most of cab roof cut off. Different makes may be different but I don’t think the bit of tin on the cab roof has much, if any, effect on strength, it’s in the A and B pillars I believe. Not that is matter lol
If you are wanting a fixed bed in a van up to 6 metres that isn’t a drop down or overcab I think you may struggle. Mine is fixed French bed with L shaped bathroom/shower going behind the bed but it is 7.5mtrs long. I don’t find space a problem with the fixed bed but it depends if you want to hold dances inside and general layout
As you can see in the two pics that extra 1.5mtrs makes a big difference. I think it really will be a case of trawling the ads to try and narrow down a few then having a look in person if possible but you already know that. Good luck anyway
