mine's a sprinter with a steel roof. if it was a flimsy , i'd use through bolts with big washersi used 292i as advised by aandncaravanservices in their solar panel install guide however the roof bolts bit seemed ridiculous to me. The top layer on a motorhome is a very thin sheet, presumably aluminium, glued to an insulation board. If the sikaflex gives way and a solar panel is loose then no way is a roofing bolt going to hold a panel in place screwed into 1mm of aluminium whilst meeting a combined 110mph uplifting headwind as suggested by some folk. Still if it makes people feel better about the limits of a glue that holds aircraft and speedboats together then so be it.
not alwaysdon't forget , no matter what the roof is made of , you're just gluing to the topmost paint layer. i use roofing bolts as well
My glass panels are fitted to roof rails; but the roof rails, as well as being taped down, are through-bolted the metal roof with penny washers acting as spreaders on the insided before the nut. I did consider riv-nuts briefly but didn't like the lack of load-spread. I also never considered relying on adhesive to hold on top of the paint (and Sprinter roof paint is renowned for peeling to boot!)mine's a sprinter with a steel roof. if it was a flimsy , i'd use through bolts with big washers
Thanks everyone for your input.
I've gone with the majority verdict both here and elsewhere on the internet and ordered 512.
''I dont want mine going awol '' or any passers by going ow !You lot have got me worried now... my 2010 ducato pvc has a solar panel right at the front of the roof and being a ducato, paint is already peeling in the gutter areas. I have no idea who fitted the panel nor how it is fixed. I can see white sealant/adhesive but cannot see any screws/bolts due to the design of the brackets. I have not yet had a look under the ceiling covering but will do tomorrow.
K ?
to be fair , windscreens are glued to a steel flange more or less opposite the wind direction . the wind would be pushing the glass against the flange. a solar panel , with its cooling gap .has the wind pushing up from underneath ,and possibly lifting from aboveThink if you use the correct build process . Primer. activator that is comparable with the sealer it will be ok. I Understand putting extra fixings in. And each to there own. Most Windscreens are bonded in. But i don't see any extra fixings in them. And nobody seems worried about a windscreen debonding
