I have only ever glued one solar panel so am no expert but i refer people to this from a source I have found very knowledgeable
What adhesive should I use to attach my Flat Glass Solar Panel?
A motorhome travelling at 70mph into a 40mph head wind, effectively has a 110 mph hurricane blowing across the roof top. That can be a huge force acting on a Solar panel so we think 'belt and braces' security should be the order of the day.
We suggest Sikaflex 292i which is described as a "HIGH-STRENGTH FASTENING ADHESIVE FOR STRUCTURAL ASSEMBLY". It is suitable, even in challenging Marine environments.
Many forums advocate the use of Sikaflex 512 Caravan Sealer.adhesive which is primarily a sealant that also has some bonding properties. Sika say it is NOT a structural adhesive.
Sikaflex 292i is a full marine grade structural adhesive, not that different to Sikaflex 252, but 292i has superior Salt water and chemical resistance and 3 times less shrinkage than the 'best of the rest' so far less chance of there being gaps letting water in the roof.
Sikaflex 552 also gets a recommendation by the Sikaflex team, but the tensile strength of 292i is slightly superior.
Note that neither Sikaflex 252 or 292i are suitable for gluing all Plastics, 252 has a warning that any plastic under stress and potentially subject to stress cracks, MUST NOT be used with 252. The same applies to 292i.
Some of the adhesives specifically mention they are not suitable for ABS plastic which was the material used by one set of feet we saw.
Other adhesives, like the Dekasyl MS2, have notes in the documentation that they are also unsuitable to bond some plastics, like ABS.
