Just got to find one that goes in the hole and is energy efficient
Width is likely to be main constraint and getting rear coil cooling - side skin is very neat but effectively adds significant width.
Presumably you've got a bit to play with on height as converters never seem to put fridges on the floor?
I have a cupboard underneath, but that is basically there due to the wheelarch - the fridge is directly above.
I am not wanting to chop the furniture around so basically anything bought will be the same physical size or smaller. I could potentially go wider in terms of fitting space - but if I did that the fridge would neither get though the door (too narrow) or get into the kitchen area (walkway same narrow width as hab door), so not actually an option anyway.
This is the primary contender for a 240V AC Option -
https://amzn.to/3kAMa8i
The height is near-ideal. The width means easy to get in and can make some kind of side fillets to make it look neat. Over twice the power consumption of the
Inverter fridge, but a lot of that is due to the Freezer section. As soon as you add a 'proper' freezer, you more than double the power consumption - the cost of ice cream!
It doesn't really look like a Motorhome fridge due to it being a "white goods", but could put some vinyl covering over the doors easily enough. The modern trend for Motorhomes seems to be black fridges - so could turn it black, or maybe a dark silver-grey to match the heater frontage. I think easy enough to sort that
I do have another contender - an actual Motorhome Fridge of the 12V variety! Would be a slot-in fit (which means another door struggle though
) and a lot more expensive inevitably, but actually pretty well priced compared to the 12V alternatives or the 3-way alternatives.
This one appeals despite the price as you can control the Fridge and Freezer independantly (that is a rare feature) and so if you need to save power, you can even use the fridge but turn off the Freezer and halve the consumption (obviously not keeping any frozen products in there anymore!). That could be very handy if wildcamping in the Winter say and
solar no use. Just waiting to see how much my price will be to decide which way to flip.
(PS. The 'proper' 12V motorhome fridge above in normal use (freezer on) is at best only a couple of percent more efficient than the 240V fridge/freezer in my link. Decent domestic appliances nowadays really are just as good as the 'energy efficient motorhome' ones)
