@Jenrai , Error Code 11 can be quite misleading.I spoke to soon!! Just arrived back from a few days away running the fridge off gas. No problems until the last day when is started flashing with error code 11.
The manual says its a supply issue but I have 3/4 tank of LPG. It runs on battery, with the engine running and 230v on hook up but not gas.
So I am desperately ringing every place in Sussex I can find to get it fixed before next Thursday![]()
I just dont have the confidence or skill to be poking around in the fridge workings.
I hope I'm not telling my grandmother how to suck eggs - but . .I would have thought if it has flat unvented sides, insulation would be fine? but it is not something which could be easily removed once in place, so have to think hard on this one I guess.
I would almost certainly add some 'programmable' forced venting at the rear with fans either blowing at the bottom or sucking at the top (or both!) - as the vents are there,may as well take advantage of them
The fact this is available in black makes a big difference. Silly I know, but if you are spending tens of thousands of pounds on a Motorhome, you don't want to cheapen it inadvertantly - and the white fridge could have looked like it was just shoved in the hole. The black one I think will look right. (the 12V option will have to be a pretty keen price now to retain my interest!)
I would think logically that because fridges tend to be fitted closely to cabinets either side, the ventilation would generally be arranged around the back - and the sides woulds generally have insulation on the sides between the outer panel and the fridge inside.I hope I'm not telling my grandmother how to suck eggs - but . .
If the fridge ditches heat via coils directly under the side skins then those sides need air circulation. Close fitting insulation will stop the fridge working.
If the dispersion is via the back skin then the chimney system in a motorhome home will be great and temperature controlled forced ventilation will be good in hot weather.
If it's side skinned and there is space (20-25mm) either side and above the fridge with good external vents it will work.
To be effective any forced ventilation will need to be well considered to get additional air flow in the right place.
It's up to you of course but it'll only take a few minutes to reset the 'computer' as suggested by Wildebus - if after doing that it does try to light the gas but fails you can quickly clean up the burner and air inlet holes.@wildebus @Markd Thank you both for the advice and the support. Having phoned every place I could find everyone is booked, the end of August being the earliest. But I did have a lengthy conversation with a very knowledgable mobile techy. He said reseting the fridge a few times might clear the problem, he also mentioned that it might need a new pcb. At this point he warned me that getting hold of a pcb could be a problem as he says there is a supply shortage. No problem, as I know a local dealer that has all sorts of stuff. So after a short round trip and £165 later I am now the proud owner of a new pcb, just no one to fit it.
Going to open her up tomorrow and see what I find
I'll update you after a rummage around.
I think the entire assembly is removed and the plugs swaped over, rather than just the actual Printed Circuit Board itself?You're daunted by the prospect of changing the pcb but you've done most of the leg work.
The cover is off and you've got a record of which plug-wire goes where.
I suspect that all you would need to do now is take out the two self tapping screws through the board and it would come loose.
