Winks
Hi, in your van, the difference in GVW (Gross Vehicle Weight) and GTW (Gross Train Weight) may be just 1,000Kg, but it does not actually mean you are necessarily limited to just 1,000kg on the trailer - For example if your van is 500kg under the GVW, that 'spare' 500Kg could potentially be used on the trailer and give you a trailer weight of 1,500Kg (actual towing limits are not detailed on the VIN but should be in the vehicle documentation).Morning Rog
How do you go with train weight and the like? Looking at our max train weight it would seem the trailer/tow car is limited to 1000kg. I can't see your weights being greatly different to ours but I'd guess the trailer and car add up to more than 1000kg.
Here's our plate.
Cheers
H
I guess you could reverse the car onto the trailer to distribute the weight further back if need be?I was going to ask about trailer nose weight - it'll be what it is as it doesn't look as if the car will go much further back.
Only think to look out for is to ensure that front axle load doesn't drop too much.
Have fitted the drop plate, firstly lowering by 100mm, which was too low, and then by 50mm which appears to be just right.Good idea re drop plate as trailer nose up , not the best ideally , just be careful with drop plate fitted if going onto ferry or other ramps , Luckily you have ability to pump air suspension up if needed for clearance. Have you checked trailer for nose weight ?
Quite agree Bill, which is why I will be devoting tomorrow to getting it right.It’s important to load a car forwards on a trailer for stability when towing.
Moments of inertia means your arse will swing about just say it as it is we’re all grown ups ??It is very unusual to fit a front engined car on a trailer facing rearwards as it makes it very difficult to get noseweight correct , so usually only VW and to a lesser extend Porsche . it also makes moments of inertia more likely to be a problem .
Parcel arrived, safe n sound Gordon. Many thanks!I broke em roger?????????
No that’s ok, gross train weight is fine, your calculations were pretty much spot on. The loaded trailer weighs 1120kg.Your train weight might be quite critical kerb weight 107 800kg approx BJ micromax mam 1300kg load 1000kg so unladen 300kg so min trailer weight loaded 1100kg @RoaminRog
