Been raining on and off all night and this morning in Hull. Think this has been the worst weekend weather wise we have had in Hull this year, usually get a fair amount of sun and a good bit warmer than Buxton being a thousand feet is so lower down
Edit: should have said thirteen hundred feet or so lower down as our house is 1320 feet above sea leavel and I think some bits of Hull may actually be lower than sea level.
You will only want one or the other Lee, seeing as Buggy is flat you may be better with snow shoes or you could wear some of these ?I must remember to take artic clothing when I go to Bugsworth.
Do you think snow shoes and skis will be needed?
You will only want one or the other Lee, seeing as Buggy is flat you may be better with snow shoes or you could wear some of these ?![]()
If there's anyone on here who needs high heels, less than you..... I'd be flabbergasted.Is it fancy dress then, I'll get out my heels and suspenders out then.
Suspenders? While I'm no expert... You'd have to have extenders fitted to the elastic dangly bits.. A specialist job.
Lovely evening here, 1.5 Kw Dimplex warming the whole hovel.
