A bright and sunny day.
I've just got back from painting another masterpiece.
A spot of lunch and then to sort out the fridge in the van.
Been raining on and off all night and this morning in Hull. Think this has been the worst weekend weather wise we have had in Hull this year, usually get a fair amount of sun and a good bit warmer than Buxton being a thousand feet is so lower down
Edit: should have said thirteen hundred feet or so lower down as our house is 1320 feet above sea leavel and I think some bits of Hull may actually be lower than sea level.
I must remember to take artic clothing when I go to Bugsworth.
Do you think snow shoes and skis will be needed?
Lovely sunny lunch outdoors.
I bay tree planted.
Microwave and kitchen Blitzer repaired,
Olives ready for bottling.
Child Bride bustling about , Spring cleaning.
Must have been getting stir crazy, untilil the Sun came out again
You will only want one or the other Lee, seeing as Buggy is flat you may be better with snow shoes or you could wear some of these ?:)
Cold, no rain in Milnrow Lancashire before setting off to work
Its been a beautiful day in Middleton Manchester (Work) no rain, a few hours of sun, but cold
We wild camped beside a reservoir last night:
A lovely spot but about midnight the wind got up and by 0100 it was blowing more than a gale with the Moho being shaken quite dramatically and the sound of debris flying.
At 0430 I gave up and moved the Moho back a few metres from under the trees and away from the drop into the water.
Today we drove further up into the Sierra Nevada to the Alhambra in Granada. From the palace walls there was a great view of the snow up in the mountains:
Colin ???
Is it fancy dress then, I'll get out my heels and suspenders out then.
If there's anyone on here who needs high heels, less than you..... I'd be flabbergasted.
Suspenders? While I'm no expert... You'd have to have extenders fitted to the elastic dangly bits.. A specialist job.
Lovely evening here, 1.5 Kw Dimplex warming the whole hovel.
I'm a bit worried about you getting my dangly bits close to your 1.5Kw Dimplex.
The toughest thing about the high heels is getting them in size 15 and bumping your head when going through doorways.
It was minus half a degree when I parked up above the house early hours but saying 3 degrees now, it’s a bit foggy but still quite dark. Better inside the van than out
Users who viewed this discussion (Total:15)
