Mr and Mrs Tupcox
Enjoying a few days out on East Coast parked up at Hunstanton on sea front .
Blood freezing.
Blood freezing.
'Sunny Hunny' was a start and end of season day trip when I lived just outside Peterborough [Castor] between 1983-87, when I was nobbut a youth ... Almost 40 years later, I'm nobbut an old git ...Enjoying a few days out on East Coast parked up at Hunstanton on sea front .
Blood freezing.
Depending on year of your motor, Annie. Could be an idea to have gearbox oil drained and renewed during service.Well after repeated attempts to fix the fridge myself I bit the bullet and booked it in to get a professional on the case also having a full engine service while they have it in.
I have clean roof envy ..........Thought I would add a couple of extra solar panels. The roof has 4 x 50w panels so worked out I could add another 2 x 80w giving us 360w total. Need to rewire the originals as they are in parrallel and need to be in series for it to work correctly. So 2 x 50w in series.+ 2 x 50w in series + 2 x 80w in series and then connect the 3 sets in parallel should give something like 40v at 9a. The panels that are on are pop riveted to aluminum square tubes that are stuck to the roof with Sikaflex. Plenty of area for the glue. Just raised them off the roof to give about 2mm of Sikaflex. The first 4 have been on for 2.5 years and no sign of them coming off. I used semi flexible panels as they are not as heavy as the framed version. Keeping them off the roof allows ventilation and makes it easier to remove one. Just the plastic trunking to add.
Its a bit dirty at the moment. When I have done playing about i will give it a good polish. Not much to do now its got more panelsI have clean roof envy ..........![]()
You carnt have to much i say.Thought I would add a couple of extra solar panels. The roof has 4 x 50w panels so worked out I could add another 2 x 80w giving us 360w total. Need to rewire the originals as they are in parrallel and need to be in series for it to work correctly. So 2 x 50w in series.+ 2 x 50w in series + 2 x 80w in series and then connect the 3 sets in parallel should give something like 40v at 9a. The panels that are on are pop riveted to aluminum square tubes that are stuck to the roof with Sikaflex. Plenty of area for the glue. Just raised them off the roof to give about 2mm of Sikaflex. The first 4 have been on for 2.5 years and no sign of them coming off. I used semi flexible panels as they are not as heavy as the framed version. Keeping them off the roof allows ventilation and makes it easier to remove one. Just the plastic trunking to add.
can you use your bus pass with this, Jeff?Just ordered a bus bar going to fit new main switch as well bit of a tidy up with the wiring .
Your a cheeky sod Terry lololcan you use your bus pass with this, Jeff?
Well done Terry.Motorhome returned today, MOT done, no advisories. New CV joints fitted, ABS light now off. I went down to garage to check underside of MH while gearbox oil was drained and replaced. Happy to say, really good nic underneath, due to previous owner doing a thorough protection job some years back.
Gearbox oil; 75W90, 2 litre's @ at a total price for 2 litre = £41.00. OUCH. Anyhooooo, all done motor running sweet![]()
I was soooooooooo happy, I booked the tunnel for next month!!
Must show this post to Val ...........Our van was still filthy from the drive down when we moved on an icy December night. today Susie cleaned it up and it’s back gleaming again.
