mid4did
Whether you buy "that bull" or not, you have publicly and falsely accused both myself and @mid4did of carry out an illegal act. That is defamation: "a false statement that injures a third party's reputation", and I take exception.Sorry, I don't buy that bull. If there was a non-damaging refrigerant, don't you think the industry would be using it?
Hydrocarbon vs CFC Refrigerants
Hydrocarbon refrigerants and chlorofluorocarbon (CFC) refrigerants differ significantly in their environmental impact, chemical composition, and usage. CFCs were the original refrigerants, composed of carbon, chlorine, and fluorine, and were widely used in refrigeration and air conditioning systems during the 20th century. However, they were found to be harmful to the ozone layer, leading to the formation of the Montreal Protocol in 1987, which aimed to phase out their production by 1995 due to their high ozone depletion potential (ODP) and global warming potential (GWP).
Hydrocarbon refrigerants, such as propane (R290) and isobutane (R600a), are natural refrigerants that have emerged as a more environmentally friendly alternative to CFCs. They have negligible environmental impacts, with zero ODP and very low GWP, making them a sustainable option for refrigeration and air conditioning systems. Unlike CFCs, hydrocarbons are non-toxic and have excellent thermodynamic properties, which make them efficient in cooling applications. Additionally, hydrocarbons are by-products of the petrochemical industry, making them readily available and cost-effective compared to synthetic refrigerants.
The transition from CFCs to hydrocarbon refrigerants was also driven by the need to reduce greenhouse gas emissions. While CFCs were phased out due to their ozone-depleting effects, hydrocarbons have gained popularity for their minimal contribution to climate change. They are now increasingly used in domestic and commercial refrigeration applications, as well as in mobile air conditioning systems, as they offer a more sustainable solution without compromising performance.
In summary, hydrocarbon refrigerants are a more environmentally friendly option compared to CFCs, with significantly lower ODP and GWP, better energy efficiency, and cost-effectiveness. Their adoption has been supported by international agreements and regulations aimed at reducing the environmental impact of refrigerants.
I don't agree sorry. You can argue all you want with all your knowledgeable replies. It won't alter the fact these gases have been deemed safe for the environment.Sorry, but I think you are wrong. You can bluster as much as you like, but that won't change my opinion.
Using hydrocarbons is indeed less damaging, which is why new ac systems use hydrocarbons, but they don't work in r143a systems.
The stuff in those cans is not a hydrocarbon refrigerant.
Basically, the new systems use a sort of propane, with the inherent fire risk. More relevantly, they whole system has to be designed to use hydrocarbon refrigerant
Which "these" gases? The ones that are safe, or the ones in the cans?I don't agree sorry. You can argue all you want with all your knowledgeable replies. It won't alter the fact these gases have been deemed safe for the environment.
We use the 'Broom Cupboard [not big enough to be a garage!]' twin 13 amp socket that you fitted for outside cooking on the Induction Hob, and for charging the ebike batteries, but we have to have the cupboard door open, so restricted to using it in dry weather ...Around 4 years ago I was down in Henley-on Thames at Swiss Farm Campsite and could get no TV Signal for some reason. The Campsite actually had a TV Aerial Point at every Pitch (or at least at every fully serviced pitch, which is what I had, being Posh) and I thought "that is handy" - or it would have been if I had a cable to use and plug in!
So when I got home, decided to fit an external TV and Sat Point on the side of the van
Maxview - Outside
It turned out I never actually used this in these last 4 years
So decided to change this out for something maybe more useful? Bought this external AC Outlet last year and today was the day to install!
I do like how flush this socket is and also the way the cover is secured with magnets rather than a physical catch.
This is a nifty outlet and as well as the standard 13A Plug Socket, it has knockout positions for a 12V socket plus TV and Satellite connections, but given I didn't use the others for years, didn't see much point in adding them.
Mains Outlet - Inside
Inside, the Aerial connections went to a typical TV/Aerial socket
CBE Block - Before
That was pretty redundant now and I never used the 12V outlet either, so swapped that for a pair of switches instead
CBE Block - After
One switch controls the power to the new AC Outlet Socket, and the other I have put in line with the socket that the Microwave plugs into, so I can easily switch that off remotely instead of unplugging it when not in use.
A key use for this socket will be to use the little Induction Hob outside as shown here
And I can see this particulary useful for things like eBike Battery Charging, as that is something that ideally should not be done inside the van for safety reasons.
I have a socket in my external 'electrics' locker which is handy but the wrong side of the vanWe use the 'Broom Cupboard [not big enough to be a garage!]' twin 13 amp socket that you fitted for outside cooking on the Induction Hob, and for charging the ebike batteries, but we have to have the cupboard door open, so restricted to using it in dry weather ...
Neat. Are you related to the tory who announced that we've had enough of experts?I don't agree sorry. You can argue all you want with all your knowledgeable replies. It won't alter the fact these gases have been deemed safe for the environment.
I always keep them outside, but under the van to protect from rain, and usually right next to the LPG tank (oh, reminds me ... I really need to fix that gas leakI hope you'll charge them.a bit further away than that, for safety reasons.
I think you need to stand back and have a good look at yourself.Neat. Are you related to the tory who announced that we've had enough of experts?
You seem so obsessed with your POV that you're not prepared to even consider that you might be wrong. However, a little research via Brave AI asking "Which hydrocarbons are compatible with R134a" turns up the following:I'm sorry, but I don't believe what they say.
If there was a 'pour-in' hydrocarbon replacement that worked on R143a systems, everyone would be using it.
So, you've doubled down again. While @mid4did has presented actual evidence to back up his POV, you've just argued by assertion -- a classic logical fallacy.Neat. Are you related to the tory who announced that we've had enough of experts?
At the end of the day, refrigerants that work in r143a systems are damaging to the environment. Fact, not opinion.
Hydrocarbon-based refrigerants are less harmful, but cannot be used in systems designed for r143a. Fact, not opinion.
Hydrocarbon refrigerants have NOT been deemed safe for the environment.
They have just been deemed less damaging. Fact, not opinion.
Point is Jeffrey, will you use the hot water and give yourself a wash?I am running the water heater at the mo and found out its actually only using 890 watts happy days.
