Oh dear not a good recommendation for food grade ?.We’ve had 3 food grade flat hoses, the ones that are wound round a cassette. After a year or so, all 3 started to impart an unpleasant antiseptic taste to the water, just before they started leaking. We now use Gardena 13mm hose. 2 lengths that we can join together if needed, will stretch to about 15 meters. Enough length to fill the tank from any water supply we have encountered and after nearly 3 years, no nasty aftertaste or leaks.
We have never used any hoses that we have found attached to taps. I know my own hose is clean so use that all the time.
I generally disinfect any water taps we come across on aires in Europe, you never know what’s happened to them before we get there.
We carry a watering can too, but only use it if we can’t get close enough to a tap.
Was on a site many years ago and witnessed a guy cleaning his toilet cassette with the fresh water hose attached to the tap, sticking it inside the swivel tube to fill and rinse…..I have food grade hose and various fittings to go with the hose lock adaptors which include the screw on fitting to tap as to enable hose lock connection
id rather use my hose as I have seen (not a lot) people hosing tneir cassette toilet with fresh water hose agh
Thats way to regular for me TerryI sterilise every ten years whether it needs it or not Gordon, it coincides with bath night as well![]()
We are the same Jeff, over 19 years in ours and still drink water out of the tank, never had a problemIn the eight and a half years we have had the van we have always drunk the water out the tank and never had any bother with bad tastes or upset tummy .
FWIW, that's not my experience. I have a set that comprises a 3/4" tap connector with a 1/2" adapter and a clamp on connector for the rare occasions where the threaded connectors won't fit (something similar to this one on Amazon). I have yet to find a tap that I can't connect a hose to. However, I have at times been 'snookered by distance' where my hose won't reach and for that I've fitted a 'Command' hook above the filler so that I can hang a funnel to fill the tank using a 10-litre container.[... ]you will find you will need all sorts of hose attachments to suit various taps on your travels if you use hose, [...]
