tompa
Hi all, I know these fridges seem to to cause people endless problems when they have had a few years use but ours is a bit odd. It works fine on hook up and 12v but not on gas. It will light up no problem but eventually shuts down. However this can take anywhere from a few minutes to a day or so. The shut down seems to be most common during the night. It will reignite if switched off and back on. I have done all the usual stuff several times, cleaning the flue, cleaning the burner and jet. I have now replaced the burner and jet completely. I have cleaned and checked the twin solenoid gas valve and tried easing back the valve actuating arms to compensate for wear over time when contacting the stops. The only thing I have not checked is the electric control box as I can,t find any of the correct readings to check against with the meter.
Does anyone have the correct values for the electrics or hopefully has anyone had an identical problem that has been resolved. If so how was it sorted? Please don,t take offence at this but I am long past the stage of try this, try that or it might be. I am just looking for help from those who have resolved the exact same fault or someone who can give the correct reading for the electrics. Cheers, Jim.
