The LB seems to be getting a charge from the panel but not the VB
Or should I go for one of these?
That first charger ... Very expensive for a mains charger putting out 0.8A. CTEK are good tech, but may as well get a proper one such as an CTEK MSX5 at least (such as this - https://amzn.to/3GMENFJ ) if you want to go the mains charger router to maintain the battery. 0.8A is not even enough to cope with some parasitic loads on a vehicle.Not sure about either of those options for my van.
I already have an MPPT controller to charge the VB & LB but not enough sun for it to do it at this time of year, we seem to be in cloud 6 days out of 7, the EHU is too expensive and doesn't charge the VB only the LB so I'm thinking (mentioned elsewhere) to have the EHU on a timer for one hour per day, and then plug in the VB to a charger plugged into a hab socket.
So the OP question remains, bear in mind I'm not able to go crawling about running wires etc.
I'm very tempted to go for the https://www.amazon.co.uk/CTEK-MXS-5...1b626848a3b2f&language=en_GB&ref_=as_li_ss_tl as it is a fit and forget, but would 1 or 2 hours a days be enough, I'd do it overnight to get the cheapo electric, and any solar passing by.That first charger ... Very expensive for a mains charger putting out 0.8A. CTEK are good tech, but may as well get a proper one such as an CTEK MSX5 at least (such as this - https://amzn.to/3GMENFJ ) if you want to go the mains charger router to maintain the battery. 0.8A is not even enough to cope with some parasitic loads on a vehicle.
It would also not do anything for you in the summer months when you CAN use solar charging.
The option Trev suggests to you ref Solar Controller with Starter Battery conenction, you essentially have already but it doesn't work for you in the Winter - a very common situation. These are only good for solar as well, so if you plugged into EHU it still would not charge the Starter Battery.
You really need a single solution that works on both EHU and on Solar ....
For your purposes, the Victron Cyrix-CT is overkill and not the right option IMO for a couple of reasons. You just want to be maintaining the starter battery and you don't need an expensive voltage sensing relay rated at 120A in order to do that. (too pricey, overly big). If you like that concept, you could buy something like a TEC 3M Towing Relay (https://amzn.to/3OJpY98) which is small, basic, but would work. These are used typically in towing electrics to run a fridge in a caravan and inadequately charge a caravans battery, but can be used for your purposes (when it comes to wiring diagrams, your Starter Battery is the "caravan" and your Leisure Battery is the "Car").
That kind of setup would operate when you have either EHU or Solar active, so better than the dual solar controller anyway
You have the basic direct cable you have used in the past of course, but you want to go away from and get a "fit and forget" option.
What I would do for is a proper designed-for-the-purpose battery maintainer. There are a few around made by various companies. Some are incredibly simple and overpriced for what you get (Resistor and Diode in a plastic box for £25 from Votronic for example), others are a bit better but overpriced and overhyped (Vanbitz Battery Master for £70 but is still a pretty basic voltage dropper) and others are much better - the Trik-L-Start (https://www.bestconverter.com/TRIK-L-START_c_210.html) is an example of where you are starting to get a decent product (that is lead only. the Lithium version is the AMP-L-Start.
But IMO the best solution is the AMT2-2 Battery Maintainer (and yes, I do sell them, but that is beside the point - RoadPro sell them cheaper than me anyway (https://www.roadpro.co.uk/product/0.../ablemail-amt12-2-trickle-charger-c8450/C8450 but don't give you the wiring) ).
The AMT12-2 gives you selectable pre-set programs to suit whatever Vehicle and Battery combinations you have, plus can be customised directly as you want if you go for the optional Bluetooth module. And can be set to operate even when you are not able to charge the Leisure Batteries (no solar, no EHU).
What I would suggest is also looking at the add-on connection accessories. Makes it very easy to swap between vehicles that way so you could also use on the car occasionally (what no one gets told is that it is a good idea to do a full battery charge on a starter battery - ANY starter battery - once a month)I'm very tempted to go for the https://www.amazon.co.uk/CTEK-MXS-5...1b626848a3b2f&language=en_GB&ref_=as_li_ss_tl as it is a fit and forget, but would 1 or 2 hours a days be enough, I'd do it overnight to get the cheapo electric, and any solar passing by.
At least this can be fitted easily even by me and come out of the van when we change.
Some people say you should unhook EHU before starting vehicle. I don't do that (and have driven away with lead still plugged in!!) but it might depend on what is fitted?Good idea David, I just one other query before I buy one, is are there any issues leaving it all in place and then starting the van up, will it harm anything, do I need to unplug it from the van socket etc?
A comment for others reading this and have a Sargent system... if you switch the control panel to VB (Vehicle Battery), then the mains charger will charge the Vehicle Battery instead of the Leisure Battery.Actually, after a bit of possibly joined-up thought, I might be better off letting the CTEK do its job and leaving the vans charger turned off and EHU on full time.
You never know About a year ago my car battery was totally dead. not got a clue why. It was ok the time before that and after a jump start and a drive it has been fine since. a weird aberration.I don't know how many times I've had to repair the EHU plug.
PM me about bits, not sure I'll need them as the car always seem to fire up instantly.
I bought the sec9nd 9ne when the wifes carbattery was playing up but ended up buying a new battery .
I decided to go and look for these bits .... didn't find them, but I did find my Ryobi Impact Driver I have been looking for for around 4 years, so that was a resultI don't know how many times I've had to repair the EHU plug.
