marchie
'Welcome to Fife'; and you're more than welcome to it ...Started to put the washing back in the van from the last trip ready for our trip to Fife the boarders and Northumberland.![]()
Did you need to fit a reinforcing bar when you removed the towbar? I lost some of the payload gain by doing this but on my van it was essential to do.I did the same to my MH a couple of years ago, saving just under 40kg, we also had a tow bar mounted bike rack weighing another 16kg that we used, so 56kg hanging off the back before any bikes were put on.
I removed it all and mounted a fixed bike rack, about 8kg, and as you say leaves a useful additional payload.
Ye might have kept the gaps even Annie, where's the OCD gone to ?Lost my fridge vent so an emergency repair was needed until I can get home you can hardly see the join.
I'm quite pleased with myself today, I finally managed to do some little upgrades to create not more space but better space.
I replaced the original huge dining table when we go the van and put it in the same track as it was already there, but it's at the forward side of the wardrobe so I always have to move the clothes back to get it out and they always slide forward with movement in the van (is there anything I can put on the rail to keep hangers from moving?) so I have to move them again, so I have moved it to the back wall of the wardrobe, it is now much easier to put in and out, it is retained by one of the swivel catches so it's safe and can only fall onto the clothes anyway.
I took the plate rack from where it was into a smaller cupboard as it was taking to much room where it was and Liz (short arse) struggled to reach them and rotated it 90 degrees so the plates don't roll back and forth as before when driving, I tried it loose like this last week so I know it is more better and less rattles.
I also took the two mug/glass racks out and put them onto the outer wall of the van, I put them as high as possible but still able to use them and there is space under it for maybe a spice rack or similar.
Back is on fire now so it's Tramadol time.
Next job it to make/buy some shallow trays to fit inside the wardrobe base just tall enough to put tins and jars and not have them falling over or rattle as Liz (short arse) struggles to see what the tins are, so any suggestions (other than stopping calling her short arse) most welcome.
![Vanity Unit2 [Desktop Resolution] [Desktop Resolution].jpg Vanity Unit2 [Desktop Resolution] [Desktop Resolution].jpg](https://motorhomer.com/data/attachments/32/32296-bef2c88a513d9b96ca91fcea82dfe14f.jpg?hash=vvLIilE9m5)
Definitely worth it! We had a refillable system fitted on 13th July 2021 at eye watering cost [and a Lithium Battery the following day at even more cost!], including buying the European Adapters, and a spare pipe/regulator for the remaining Calor exchange bottle ['in case you go wild camping in the north of Scotland']. The ability to top up the refillable bottle when you pass an LPG Service Station [but not Total in France who forbid refillable systems] is worth its wait in gold, saving the need to travel off site to fill up. We tend to refill as the first 11kg bottle is approaching empty, so that we have the belt and braces comfort of 2 full bottles, especially in the Winter Sun season, at all times. Great for off grid stays, so that lpg operates the fridge and the hob/heatingToday I researched a refillable LPG system to put in the Motorhome to replace the Calor exchange bottle.
We’re doing it because we are off to Europe this summer.
I hope the cost is worth it.
You can buy corrugated silicon tubes which are slit and which are intended to go on an oven pullout metal shelf. If you have a slide out hanger rail they fit well and can be held in place with a couple of tiewraps.I'm quite pleased with myself today, I finally managed to do some little upgrades to create not more space but better space.
I'm picking up from my local Safefill supplier another 10KG tank to accompany my current 10KG tank, tomorrow. I am hoping it will fit in gas locker, if not, I'll return 10KG tank, and swap for 7.5KG tank.Today I researched a refillable LPG system to put in the Motorhome to replace the Calor exchange bottle.
