Greengrass
Trouble is, as you put the sockets in there 30 years ago, the world has gone metric and your Whitworth sockets and most of your A/F sockets won't fit anything now....... I have a full box of sockets, ratchets etc (with an ancient bit of carpet copydexed underneath c. 30 years ago). The socket set is just shoved into the driver's seat tray (elektroblok on passenger side), and has travelled like that for almost 17000 miles without moving,........
If those Whitworth & A/F sockets are going spare I will gladly take them !!Trouble is, as you put the sockets in there 30 years ago, the world has gone metric and your Whitworth sockets and most of your A/F sockets won't fit anything now.
Where are you reiverlad? I've got a box of whitworths you can have. I'm at M1 J20.If those Whitworth & A/F sockets are going spare I will gladly take them !!
Just fell heir to my dad's Morris Minor & I will need to collect all those long forgotten tools.
I am up in God's own country - the land of whisky & Great scenery !Where are you reiverlad? I've got a box of whitworths you can have. I'm at M1 J20.
I can't remember the last time I picked up an imperial spanner or socket other than by mistake.If those Whitworth & A/F sockets are going spare I will gladly take them !!
They were (and still are) metric socketsTrouble is, as you put the sockets in there 30 years ago, the world has gone metric and your Whitworth sockets and most of your A/F sockets won't fit anything now.
Have you worked out what sizes you actually need in 99% of cases?They were (and still are) metric sockets
You lot and your modern Whitworths.Where are you reiverlad? I've got a box of whitworths you can have. I'm at M1 J20.
When I bought the original sockets round about 1978, I also bought a reasonable quality set of ring spanners, that offered 8&9mm, 10&11mm etc (left most of them in France so must retrieve them!). I subsequently bought a pair of 13mm combination spanners for the trailer load bars for the bike bars, where I had to make custom security plates and longer bolts to make the clamps close safely, so 2 sets of fittings.Have you worked out what sizes you actually need in 99% of cases?
I found works out to 8mm, 10mm, 13mm and 17mm.
If wanting to reduce the size of the toolkit as much as possible, a set like this can be handy .... https://amzn.to/4d0v0K1
2 physical spanners but 8 sizes covered
I just chucked them in some new dried fruit when making the Xmas Cake ...
And they measure weight by the pound even the weight of a bridge, and they can't spell for toffee.I can't remember the last time I picked up an imperial spanner or socket other than by mistake.
I find it confusing how Americans seem to be able to instantly work out that two sizes below a 1/2" socket is a 7/16" and one above is a 17/32" but apparently cannot get their heads round a Metric system that generally involves simply removing or adding 1 to the previous size?
