Why didn't they just stick with the amber lenses and cheaper bulbs.
No idea but the amber bulbs do fade in time. And I don’t think it’s use that does it either. Maybe it’s the sunlight.Why didn't they just stick with the amber lenses and cheaper bulbs.
Who knows they certainly made sure that they have to be changed more than a non amber bulb.I thought it was heat, maybe just mainly on town traffic though.
I suspect that a lower current draw might lead to more corroded connection, not fewer. But if you fit the resistors, there isn't less current draw anywaycIndeed, I've had the odd problem but it's been with the holder and tarnish. As mentioned I've not got the slightest inclination to swap the bulbs for LEDs but surely they'd have the same connectivity issues as incandescent bulbs anyway? As for Trev's 'less draw on the alternator"
It's less than 2A once in a blue moon Trev, hardly an alternate killer mate![]()
I only mow down townies.My alternator gives well over 200A, so when the engine is running, there's plenty of power. The headlights are HID so give a lot of light for little power, and no need for a pedestrian cutter on the front
I suspect they'll be more reliable than LED bulbs.We are it seems talking about two different way to do it, I didn't buy bulbs I bought lights and wired them in.
I was lucky that these were the same size as on the Laika which had earthing issues I did a re-design on what was already there, the LED lights back in 2008 were about £5 each truck stuff is much cheaper than MoHo crap.
It's not as simple as that, LEDs like to run cool, but squeezing them into a traditional bulb shape allows very restricted heat dissipation,Same thing, just laid out in a different pattern, you tend to get what you pay for with LEDs, good no cheap, cheap no good,
