Mr and Mrs Tupcox
There are lots of police clampdowns on them right now.I'm sure if there's any trouble the OP can just say they are delivering fast food and the Police will soon loose interest.
A good place to get replacement springs is the IKEA Bargain Corner. Almost always sets there which you can adapt.Not today, but on Wednesday, I stripped down the beds' slats, they were bent the wrong way, what a cow to put them back in again, I'm hoping that I don't need to do it again if they are knackered.
I have a few more jobs to crack on with when I feel up to it, I love working in the van but me bod don't![]()
Aye, but that means going to Ikea, I think you can order slats online, I need to measure them, I didn't have a tape measure with me at the time.A good place to get replacement springs is the IKEA Bargain Corner. Almost always sets there which you can adapt.
If they are bent over, they will be knackered - how do the middle ones compare to the ones are the foot and head of the bed which don't have much weight on them?
And .....Aye, but that means going to Ikea,
have to pay full price and shippingthink you can order slats online, I need to measure them, I didn't have a tape measure with me at the time.
When he comes, I suggest you ask him to fit some suitable cables to the Inverter. The ones you have look way too small to me.
The ones on inverter are bigger than they look rated at 200 amps,,the 2 on floor are for b2b which are rated at 85amps only fitting 30amp b2b .
I would be interested in the actual size of the cable. Getting the right cable requires more than just the ampacity rating of the cable.The ones on inverter are bigger than they look rated at 200 amps,,the 2 on floor are for b2b which are rated at 85amps only fitting 30amp b2b .
All worked for 2 years in our old van
We only use small kettle air fryer both 1000w slow cooker. 80w .and Mrs cpac machine .
25mm rated at 200amps but take on board your advice to up grade to 50mm,I would be interested in the actual size of the cable. Getting the right cable requires more than just the ampacity rating of the cable.
And actually some would say I am too low on the 50mm2 cable!25mm rated at 200amps but take on board your advice to up grade to 50mm,
According to my Bosch Automotive Handbook a 70mm C.S.A. cable has a continuous current rating of 245 amps @ 30 degrees C PER METRE.. Rating goes down as ambient temperature rises.I found when I first fitted the inverter I was using 35mm cable but it was getting to warm so I fitted 70mm and everthing if ok now.
PS my invert is less than a mtr away from the batteries.
What does that mean Eric lolololAccording to my Bosch Automotive Handbook a 70mm C.S.A. cable has a continuous current rating of 245 amps @ 30 degrees C PER METRE.. Rating goes down as ambient temperature rises.
Means your cable is probably big enough.What does that mean Eric lololol
HeheheheheMeans your cable is probably big enough.![]()
