ActiveCampers
Motorhome builder? Is that yet another self build forum? I'm getting lost in all the ones appearing and disappearing. SBMCC was very busy and useful when I built (though was £ to join and read).
It's a sister forum to this one - check with phil but think the membership is carried over from here if you join it?Motorhome builder? Is that yet another self build forum? I'm getting lost in all the ones appearing and disappearing. SBMCC was very busy and useful when I built (though was £ to join and read).
True - but TBH the skills on there (when filteredIt's a sister forum to this one - check with phil but think the membership is carried over from here if you join it?
I was a SBMCC member for a short time but I really didn't like the fact you had to pay a fee just for basic access so rarely posted TBH.
That was the thing with SBMCC... You had to pay to help other people. I don't have an issue with forums having a sub for extra features - I subscribe to a couple myself and run a forum where some members subscribe, but basic accessibility? Nah, no thanks.True - but TBH the skills on there (when filtered) were fantastic and gave me enough advice to do a good job. The problem with the others forums is they don't tend to have the following... Too many around with too few genuine experts being spread out. SBMCC was annoying as after I finished and did a reasonable job, I'd like to have paid back with my experiences - and I did till I had to pay again!
Not planning to start build#2 for a few years and I'm sure it'd have changed again!
Not so, ours was VERY noisy on first install, but fitting silencer to exhaust and you have to be standing next to the van and listening for it to actually hear it. The noisiest thing is a "tick" of the fuel pump. Inside its a gentle purr.....Trust had a night next to a very noisy one.
I don't know how they can sleep in their van with a jet engine!
Avoid as neighbours unless you are deaf.
Either is doable. They always seem to come with a tank of between 4L and 10L though.do people who have got the cheap Chinese one`s use the separate tank or use the van`s fuel tank.
The physical installation is the same as an Eberspacher, so if someone really wanted an Eberspacher Airtronic but fancied giving the cheaper heater a go, they could try and and if didn't suit, swap over with minimal distruption and some parts sharing (the parts may "look" identical but be aware they are not in reality! There is a significant difference in quality of just about EVERYTHING from the heater housing to the pipework right down to the jubilee clips - but I would expect to be able to reuse the inlet/exhaust pipework, wiring for fuel pump can be reused, fuel pipe maybe (different internal diameter)).Yep, don't have fuel in habitation area - not a good idea!
I've been researching the Chinese ones in depth , and have to say, I'd go with one next time. I've even located the manuals and they are virtually identical to mine, and the parts look identical - so seems silly not to give it a go. Disposable if it fails and the install size appears the same (Mine is MV Aero rather than Webasto). Though I've seen it as a different brand in other countries.
Last time I fitted to tank (no option for safe second tank) - but would use separate tank next time.
You mention "cleaner and cheaper fuel" - what do you mean by that? Red diesel is cheaper but still has additives? Just interested![]()
I seperated this point as it is a very important point.I'd also add, teeing into fuel lines isn't a great idea on modern diesels with high pressure setups - you need to put your own pick up in the tank (generally through the fuel sender unit).
Will no doubt be accused of being a know-all and down on anyone else, but he didn't actually install it correctly"Rickvanman" on his YouTube channel, has just fitted one of these under his bed. Very simply done, and has a separate fuel tank for it.
indeed so.I have an inlet on the Eberspächer inside (big, short plastic hose with grill on end) but do they not also have an inlet outside Dave? I ask as they do inlet and outlet silencers which I have on order but not seen yet
Is normal heating oil not just red diesel? Don’t know how common it is but I know some garages sell it, one step daughter worked at in Hull certainly doesNormal heating oil? Interesting - can you get that at that price in small quantities?
My heater as I say is MV Aero - so that's all I can compare it to - I'm not sure if mine is just a tested/rebranded Chinese oneAs I say, the manual and technical diagrams is almost identical. Anyway, how "van 2" is being designed (powerpoint only, ETA 2 years+ lol) - the heater would be easily accessible and easily replaced if needbe.)
