Mobilvetta
My 2018 motorhome came fitted with a single Platinum 100amp leisure battery, I think I could really do with two leisure batteries as a safety net and although this battery is only around 4 months old I have read that if you want a twin battery setup it is best to fit the same make and model of battery and of the same age, which would involve buying two batteries.
I have been thinking of getting two of these 12V YUASA 100AH EFB LEISURE BATTERY (L36-EFB) but note they are only 100AH, were I have seen other brand of batteries that are 115AH, would I gain anything by going for a different brand of battery if it gives a higher AH rating, I arrive back to the UK tonight and want to try and source the batteries so that I have them for the New Year party at Hereford, so would need them to be delivered on the 28th December. Can't order though until I get home tonight as I need to measure the existing battery that is already fitted, as there didn't look to be a lot of room in its box. It has a 120 watt solar panel fitted, so would a twin battery setup be ok. I was going to use Alpha batteries as they offer a 5% discount to members. Is anyone using the Yuasa batteries and are they likely to be any better than the Platinum battery brand.
