yorkslass
I'm with you there on the mechanical stuff, but the problem with a motorhome is all the other stuff that seems to go wrong with them.aa phone no on piece of plastic
I also carry the French army towing strop - it just looks and feels right!
This may be nearing the truth more than you think. In my case it would mean I have to take at least one Grandchild to show me how to work the ITJust print out a new camper
Plus spare engine exhaust alternator starter motor, bunnies cord. Failure to prepare , is prepare to fail, just kiddingAs 'Millie' has masses of storage space I carry a 3.5 tonne trolley jack, a complete tool roll with open and ring ended spanners from 6mm to 30mm, a complete screwdriver kit covering the 3 main types of ends in various sizes, a full allen and torx sets, gaffer tape, multiple rolls of insulation tape, 1/2", 3/8"& 1/4" socket sets, a professional torque wrench, 2 x full sets of replacement bulbs, a comprehensive selection of spade fuses, replacement auxiliary drive belt, wide range of cable ties etc. etc.
Why not just tow a backup Motorhome?Plus spare engine exhaust alternator starter motor, bunnies cord. Failure to prepare , is prepare to fail, just kidding
Hi, have you been in the back of my motorhome (ha ah) Peter.As 'Millie' has masses of storage space I carry a 3.5 tonne trolley jack, a complete tool roll with open and ring ended spanners from 6mm to 30mm, a complete screwdriver kit covering the 3 main types of ends in various sizes, a full allen and torx sets, gaffer tape, multiple rolls of insulation tape, 1/2", 3/8"& 1/4" socket sets, a professional torque wrench, 2 x full sets of replacement bulbs, a comprehensive selection of spade fuses, replacement auxiliary drive belt, wide range of cable ties etc. etc.
Just added a new Torx set to my toolkit in the van.
Essential if you own a Renault Master as Millie Master will verify. (MM, where do you get your bulb sets from?)
think 6 is for normal tx and 5 sides for the tamper proof both have their own driversI saw those Nigel. It confused me a bit where it says '5 sided and 6 sided bits'.
Not sure what the 5 sided bits are for?
