Deleted member 2045
CAK tanks sell the shelf bars
Update on my DIY B2B performance.I've 5m total run with 50A fuse.
I only used 100A relay because it had 6mm stud connectors.
Whilst one can get 9mm blade 70A relays cable terminals for 10mm2, space on the relay and direction of feed were the main issues for me.
I used soldered ring connectors which I could tighten up firmly.
I don't run an inverter off leisure (or anywhere!) So I don't really expect more than 20-30 amp unless I completely kill the LB.
10mm2 is 70A nominal and at that current the drop is 1.2v so current would start self limiting.
Added to which I've still got the original wire - probably 4mm2?
What also amazed me was the delivery speed of he relay from Hong Kong!
I really don't think this sounds like a specially good good plan. This is why:I've 5m total run with 50A fuse.
What also amazed me was the delivery speed of the relay from Hong Kong!
I allowed for the other 4mm cable as well.For the record my link cable is 'only' 10mm² but I take your point about it's ability to carry current.
There are three issues here.Oh I see what you mean.
The 4mm² cable from original split charge relay will probably protect itself by its higher resistance as you say that may be part of the design. It too is fused - 20-25A I think.
I think I'm content that by having a far better alternator charging system I'm less likely to get a severely depleted hab battery as it will be full when I park up and the solar should cope with consumption as we don't use a lot.
Thinking more about the whole current flow thing.
Isn't what happens with a heavily discharged LB just the same as jump starting a flat battery?
We don't particularly worry about melting the jump leads in the 'boost' phase but do normally wait before taking mega current for the starter.
Oh, having a B2B will make a big difference. When you have a battery that you can only discharge to 50%, starting at 100% is very different to starting at 85%.EFB stands for Enhanced Flooded Battery so it's a proper battery rather than AGM which aren't really suitable for leisure use.
Having a B2B won't make any difference to that.
Ultimately the biggest factor in battery life is how you use it not how you charge it.
Oh yes - battery megastore are near me and the import Hankook batteries but label them as all sorts for themselves and other retailers.I suspect many battery manufactures have more than one label for the same battery. Even the name on it may not be who made it. Even within a manufactured batch I suspect the performance will vary greatly.
Just on the point of the heater, I am not very familiar with the Truma, but the Diesel Heaters have a similar issue in that they will not start up if the voltage is below a certain voltage, and this can easily happen with the load from the Glow Plug (around 12A) and the thin wiring often used.....
Even when off grid for a few days I've not got the hab battery so low that it won't run my Truma heater which is pretty voltage sensitive so the panel is just about coping.....
I'm not convinced that as I have MPPT solar keeping the battery topped up before any trip begins that I'm going to be starting at 85% charge.Oh, having a B2B will make a big difference. When you have a battery that you can only discharge to 50%, starting at 100% is very different to starting at 85%.
I think that AGM is very suitable for leisure use. In fact my batteries (which are proper deep cycle batteries, not leisure) are AGM.
I agree about Varta being a good buy.
Sounds like the same idea might work well with the Truma, just at a different point in the startup heat cycle?@wildebus
The Truma 6002 will fire ok, then when the heat exchanger warms up the heater fan needs to speed up to deliver 6kw of space heating and that drops the voltage.
Once warm like the diesel heaters much less current is needed.
A Truma 6002 has a maximum power draw of about 6A, but it is very rarely that high for more than a few minutes. A diesel heater needs about 12A for several minutes as it starts up.@wildebus
Once warm like the diesel heaters much less current is needed as the heater backs off to 2kw and runs slower
