nabsim
Not as straightforward lolThanks for the information .
So the heated lithium battery’s are the way to go .
IF you want to run throughout the year in full use .
Those that do not use the Moho in the winter would not be affected then by using an unheated lithium battery then
Only if the temp of the battery stayed below 0c all the time in use .
But if the temp is below 0c through the night and early morning but rises again before use the charge to the battery resumes .
Or have I got it all wrong again I usually do .
I was in the Highlands towards the end of December to the end of January, ended up coming back down into England because I couldn't get water anywhere, everywhere frozen and campsites shut. Back in the Highlands mid March until last Monday. First stint I was in some very minus temperatures. No battery heating or low temp cut out, no problem with battery power only fresh water.
It is down to your setup and how you use them
