Send a "gift" and then send the actual item if the buyer complains
you would think they would have said something like "was a freebie. battery arriving shortly. sorry for confusion" or similar?
Yes, the general rule is don't charge below zero, if you want a more nuanced explanation see post 39.I don’t think they can get damaged because they will not charge when below zero. Well that is the way I read it.
The Victron B 2 B and the Victron smart charger also has a lot of protection .
Anyway they had a sale at 454 per 280 amp battery but that has ended.
Saying that they seem to be always open to an offer .
My friend now has 16 batteries that people want so far . So bulk will be cheaper he is down the boat club today trying to drum up some more interest .
The best person to ask would be member wildebus.
He may pop along later
On eBay they went up to £549.99I don’t think they can get damaged because they will not charge when below zero. Well that is the way I read it.
Charging below zero at a reduced C rate will actually apply to virtually all lifepo4 but the makers/distributors stick with the 'dont charge below zero because it's an easier rule to follow. As I've mentioned before the battery's state of charge should also be taken into consideration so it gets very complicated, I've got an illustrative graph showing temp/ current and how it affects charging somewhere, I'll try and dig it out and post it. The exception are high current lifepo4 which we don't usually see in the leisure market where we see batteries aimed at maximum Ah in a given space, ie energy density. Apparently it's the addition of small quantities of Yttrium on the battery's anode plate that enable high current charging at low temps, often used in EV batteries.Battery specific, mine can charge down to -5 but reduced C rate. Last weekend saw a Roamer that can charge at -30 and fast charge at the
So, for anyone interested here's that chart I mentioned above from a research paper showing degradation of lifepo4 when charging at -15 DegC.Charging below zero at a reduced C rate will actually apply to virtually all lifepo4 but the makers/distributors stick with the 'dont charge below zero because it's an easier rule to follow. As I've mentioned before the battery's state of charge should also be taken into consideration so it gets very complicated, I've got an illustrative graph showing temp/ current and how it affects charging somewhere, I'll try and dig it out and post it. The exception are high current lifepo4 which we don't usually see in the leisure market where we see batteries aimed at maximum Ah in a given space, ie energy density. Apparently it's the addition of small quantities of Yttrium on the battery's anode plate that enable high current charging at low temps, often used in EV batteries.
uk.eco-worthy.com
Typically the Victron controllers when set to a pre-set Lithium Profile will have a charger disconnect set at 5 degrees C. This is the default for Lithium and can be either disabled or changed to another value. Last one I configured, IIRC I changed it from 5C to -20C out of curiosity (the batteries it was charging had internal heaters).Will the Victron battery charger still allow charging below 0 degrees. Or is that something that can be sorted out in the Victron settings
Were thinking of upgrading our autotrail batteries so could be interested in your batteries how much are you asking?I think you can get too complex when setting up electrics on a motorhome/campervan (funny for me to say that, I know, but I try to rein things in and get as close to the KISS principle as possible while still giving nice features and functionality).
For me, that means going for a heated battery if viable. A couple of years ago, batteries with heaters and with bluetooth were far more expensive than those without, but currently while there is still a difference of course, it is much less and a heated battery with bluetooth connectivity is cheaper than a battery without was just 12 months ago.
As it happens, I am thinking of changing my Lithiums as you can now get them with Victron Cerbo Connectivity which might be interesting for the geek aspect (definately not on the KISS path, but could be fun).
so if anyone fancies some quality 100Ah LiFePO4 Lithiums with integral Heaters and Bluetooth battery monitors and just 150 cycles out of the 3,000 quoted, let me know
Another handy feature with good batteries is how they can communicate with each other as well as internally in their BMS. These two batteries remain perfectly balanced and in sync
(the difference in remaining time is due to capturing screenshots a minute apart and a change in current from solar).
£250 each. Bearing in mind these are top quality batteries with Bluetooth BMS Monitoring and Integral Heaters with just 152 & 156 cycles used and under warranty until sometime in the 2030's.Were thinking of upgrading our autotrail batteries so could be interested in your batteries how much are you asking?
I agree. (well I wouldA fine deal for someone...![]()
Right, pack it in David before I'm forced to make a trip to Kelso.I agree. (well I would)
Also, I will include brand-new battery mount trays if needed ... https://amzn.to/3XsUeeu
These are very handy for securing down a battery if it is not 'naturally' confined by its location.
