No need to do that Del.
I have one of those in infrequent use. It still gets scores of stations, as well as the two or three I listen to. I have a feeling that one or two went DAB+ only, but I don't know which.After posting about my DAB Radio, the lack of being able to use it "BUGged" me
Decided to sort out a power supply for my BUG (9V, so had to jerry-rig from a desktop PSU) and still working and display fine
But not many tunable DAB stations as it predates DAB+Managed to find only around 13 stations that worked, but still had a few that I would use, so that is ok.
Something to maybe be aware of if buying of using an older DAB radio that it may not find all the stations you want?
Oh, I forget to add that a simple power cycle doesn't work to reset it.I have one of those in infrequent use. It still gets scores of stations, as well as the two or three I listen to. I have a feeling that one or two went DAB+ only, but I don't know which.
However, about once every two or three years, the Bug needs a reset to defaults. I'm not sure why, but it loses the will to work properly. The reset fixes it nicely.
I don't make any comment about TV. Don't have one. They're all full of people I don't want in my house.No problem with the router as I've said, ONLY the crappy TV box, which by the way, is a Nokia.
Just clarifying in case anyone is tempted to get "better TV" only £10, but cheap no good in this case.I don't make any comment about TV. Don't have one. They're all full of people I don't want in my house.
Also depends where you are to what you can pick up. DAB reception generally where I live is poor to start with, but I certainly get stations on the car DAB that the Bug doesn't get.I have one of those in infrequent use. It still gets scores of stations, as well as the two or three I listen to. I have a feeling that one or two went DAB+ only, but I don't know which.
Just look out of the window for the wooden poles.No need to do that Del.
To avoid going through BRSK's online coverage checker.What for?
Just looked on BRSK website and I'm afraid anyone who needs my full name and mobile number just to check if there is coverage in my area won't be getting any of my business.
Regards,
Del
Just look out of the window for the wooden poles.![]()
That drive is using a USB A - Micro-B Cable. It is very unlikely NOT to work on a standard USB socket, be it USB 1.0 or USB 3.0 (you know, I don't think I have knowingly come across a USB 2.0? not sure what happened from original (1.0) to 3.0?) . It will just be potentially slower, but fast enough for your need.I wonder if it's be worth getting this or similar off Amazon, I can send it back if it doesn't work.
It seems that USB 2.0 are hard to find most are 3.0, 3.2 or 3.3 nowadays, the TV is likely to be just 2.0 will the later ones work?
I keep posting evidence of my hard-of-reading issue, thanks again David.That drive is using a USB A - Micro-B Cable. It is very unlikely NOT to work on a standard USB socket, be it USB 1.0 or USB 3.0 (you know, I don't think I have knowingly come across a USB 2.0? not sure what happened from original (1.0) to 3.0?) . It will just be potentially slower, but fast enough for your need.
I put the old SDD from a laptop into an external holder that uses the Micro B connector and I can plug it into any USB socket - 3.0 or otherwise and it works fine.
However ... it is described as an HDD and and not an SSD? As it is an HDD, then it will be more power-hungry and the USB sockets on TVs are generally very lower current and may not be enough to power the drive motor? You would be better off looking for an SSD for numerous reasons.
And thanks Geek, I sort of recalled having an external drive kicking about but it turned out to be a CD/DVD drive.I'd suggest an nvme2 drive inside a usb3.1 adapter. Slightly more expensive, but far more future proof.
I've never seen a usb3 device that won't work in a usb2 socket, but anything is possible.
