In some ways that makes sense since the cost of transporting hydrogen at extreme pressures probably makes central generation non-viable. However, production of hydrogen from hydrocarbons probably isn't viable
Doesn't seem to stop them installing fast charging for EVs, whch has the same requirements.at the point of delivery and even that produced by electrolysis might not be viable as each filling station would require a huge supply of electricity
and a (certified and regularly inspected) compressor as well as tanks capable of withstanding circa 700 to 1,400 atmospheres (assuming normal testing of pressure vessels of 2 x working pressure) and the testing routine will need to be carefully considered
since (as the Titan submersible showed) pressure vessels can only take a number of cycles before structural fatigue occurs.
Also, the amount of hydrogen stored in a tank (either at the filling station or in vehicle) is a tiny fraction of the overall mass (e.g. < 6% for a Toyota Mirai). So converting the fleet to hydrogen will require rather a lot of steel and other metals. That's not to say these issues are insurmountable, but synthetic hydrocarbon fuels might prove an easier solution.
You seem to be labouring under the misunderstanding that a trace gas essential to life is a pollutant. Hydrogen as a fuel produces dihydrogen monoxide out of the tailpipe, which can actually be dangerous and is a far more potent greenhouse gas!Symthetic hydrocarbons produce CO2 out of the tailpipe. Hydrogen doesn't.
That to my noting that hydrolysis at filling stations requires a huge supply of electricity.Doesn't seem to stop them installing fast charging for EVs, whch has the same requirements.
Just like they have do do for the underground fuel storage tanks.
Titan was holding pressure out of the tank, not in it. A much more challenging problem.
Sorry, but nearly every one of your points is just plain incorrect.You seem to be labouring under the misunderstanding that a trace gas essential to life is a pollutant. Hydrogen as a fuel produces dihydrogen monoxide out of the tailpipe, which can actually be dangerous and is a far more potent greenhouse gas!
Actually, it does stop them from installing sufficient fast charging for EVs. The grid simply cannot cope and most charging facilities seem to be limited -- so the more cars on charge, the lower the current each gets. That said, the requirement for H2 is more than for EVs. While >90% of electrical energy fed to a charger is transferred to an EV's 'fuel tank', hydrolysis is relatively inefficient (<75%) and efficiency of H2 as fuel in fuel cells is only about 60% compared with over 90% efficiency of lithium batteries. Bottom line is that the electricity requirement for hydrogen is approximately double that required to charge EVs.
That said, people are desperately trying to improve both efficiencies for hydrogen, but they're not there yet by a long way.
- Underground fuel storage tanks are not pressure vessels and so not subject to the same considerations. Your point is non sequitur.
- The pressure at which Titan failed as was circa 350 atmospheres. High pressure H2 is stored between 350 and 700 atmospheres, requiring test pressures of up to 1,400 atmospheres (i.e. four times the pressure that destroyed Titan).
My bike battery is a Bosch but don't know how many components are made in ChinaI think it depends on the bike or scooter.
The fires are almost all caused by cheap Chinese brands that you've never heard of.
The quality makes have better quality batteries and better charger systems. Nevertheless, it's wise to take a precautionary approach.
It's also true of tumble driers and fridges with propane* refrigerant and plastic backs.
*They don't call it propane, but that's more or less what it is.
Probably all of them. I've got the Bosch system as well but I'm confident about their quality control standards. That said I never leave the batteries charging unattended and would never charge them overnight, same in the van. There really does need to be some system of regulation with all the unbranded crap coming in and starting so many fires.My bike battery is a Bosch but don't know how many components are made in China![]()
The chances are that eBike batteries are made of 18650 cells. The most reputable are from Sanyo, Samsung, LG and Panasonic (Japanese and Korean companies), although I suspect a high probability that manufacture might be outsourced to China. The Hungarian and Polish manufacturers probably just assembled the final product from components made in various locations, and might include "Chinese knock off" cells...Well there's a thing. I was convinced my Bosch e-bike batteries were Chinese. Just had a look, one is manufactured in Hungary,the other in Poland and the charger in Vietnam.
Sorry, but you seem to have a fantasy view of the subject. The only points I made that might be 'incorrect' are grid capacity and efficiency of conversion of electricity -- and even then the status quo is as I noted.Sorry, but nearly every one of your points is just plain incorrect.
If anyone else would like me to explain how in more detail, I'll do so, but clearly you have a Trumpian view of the subject.
Unless you put up facts how do we know?Yes, Mr Trump. Of course no-one know better than you. But you're still wrong.
