Scotia
Fleabay is where i purchased my one.can you tell me where to buy one from please
thankyou I will take a look ? did it fit strait out of the box or did you have to modify?Fleabay is where i purchased my one.
Exact fit from this seller https://www.ebay.co.uk/itm/264539763734thankyou I will take a look ? did it fit strait out of the box or did you have to modify?
thankyou on order nowExact fit from this seller https://www.ebay.co.uk/itm/264539763734
Hi Roger, are you back in sunny England?I fitted four rivnuts into my back box, to take the Spanish rear marker board.
Roll on September!!!!!
I got the lads down the garage to do an oil change when they put the new gearbox in it has a K and N air filter so no need to change thatThink we're doing a service on it maybe
You still have to give it a clean and then an oil ( specific to manufacturer spec) to work properly.I got the lads down the garage to do an oil change when they put the new gearbox in it has a K and N air filter so no need to change that
Done that last year .You still have to give it a clean and then an oil ( specific to manufacturer spec) to work properly.
Can I ask what year your T590 is please, I have a 2018 and hoping it’s a similar build to yours. Very interested in understanding what the space below the fridge reveals.Roller Team T-590 Storage.
The 590 is a 5.9 mtr coach built motorhome, it comes fairly well equipped but lacks enough storage space for us two and the dog. So while trying to venture under the fridge, more to follow on this, I found the the locker/garage affectionately refered to as the hanger was my only way of spotting the un-reachable pocket screws.
The hanger is partially occupied by a wheel arch, not that you can see it until removing the shelf top. This revealed an opening allowing access to the under fridge area and a an amount of floor.
Here you can see the shortened and lowered shelf.
And here is the gained floor space
For me it is a worthwhile gain in space.
The area under the shelf/around the wheel arch is now packed with rockwall insulation, hopefully the will lower any road noise and reduce heat loss.
The under fridge work will be posted here when I've finished.
Certainly am Shonky!Hi Roger, are you back in sunny England?
