Fergie1061
Photos of process tomorrow ( seeing as how many phitigrapher haz went hame!!!![]()
Och that's Whits wrang!! Whae am I??Auld age Ian after all yer a year aulder nooooooooo!
Remove your wallet from the seat, will be light as a feather
If you have the original Ford seats then it’s a bit easier if you remove the seat with runners from the swivel base it’s just about manageable for me then.
I don't understand what some of that is but it sounds like some serious electrickery work being carried out there.Second set of cells arrived from china (4 x 3.2 v 320ah) along with 200a Bluetooth BMS and heater pads,so assembled and box (clamping) built,both front seats removed some serious rewiring and moving of inverter,B2B / MPPT ,second mppt and end result 1 x 320ah lipo under each seat,2kw inverter and new shunt under drivers seat ,other lipo B2B /mppt and second mppt + fuses etc under passenger seat( standard Ducato single frames so a squeeze),while doing all this the new 240v fridge freezer arrived ,so that's the next job..looks good APX 850 high by 500 wide good size freezer (separate doors) bargain £120 . Plugged it in via watt meter 49wh when running
Roamer monthly 'Tech Newsletter' email arrived last night, with a detailed explanation of why heat pads can actually be dangerous. As an electronic numpty, the only bit I understood was 'using heat pads to thaw a battery from below is like trying to defrost a turkey in a frying pan - it just doesn't work' ... Siting the battery in the M/Home interior, on a raised platform to allow air circulation and to remove the battery from cold air bridging, and turning on the M/Home heating before temparatures plummet should stop the battery from freezing. If the M/Hom is in storage, the BMS will switch charging off automatically, and will wait for 8-10 hours for the M/Home interior temperature to rise slowly to the safe point where it can resume charging without causing cell damageSecond set of cells arrived from china (4 x 3.2 v 320ah) along with 200a Bluetooth BMS and heater pads,so assembled and box (clamping) built,both front seats removed some serious rewiring and moving of inverter,B2B / MPPT ,second mppt and end result 1 x 320ah lipo under each seat,2kw inverter and new shunt under drivers seat ,other lipo B2B /mppt and second mppt + fuses etc under passenger seat( standard Ducato single frames so a squeeze),while doing all this the new 240v fridge freezer arrived ,so that's the next job..looks good APX 850 high by 500 wide good size freezer (separate doors) bargain £120 . Plugged it in via watt meter 49wh when running
Nice one seen the guy selling it on the fb page I was gonna offer him £100 more after you mentioned you were interested just to spice it up.Bought it a winter face mask, picked up a good as new polar screen cover for a bargain price.View attachment 74587
Time Waster Aborted Transaction.Nice one seen the guy selling it on the fb page I was gonna offer him £100 more after you mentioned you were interested just to spice it up.
