Obanboy666
Switched the ehu on and grabbed a tee shirt to wear as non in house lol !
Did it work? was it worth it? http://www.motorhomebuilder.com/threads/split-chargers-b2b-relays-which-one-or-both.66709/Fitted a new Split-Charge solution to Clarence ready for the VW Busfest and Southern Roadtrip
The CTEK D250SA + Smartpass is £600 for a 20A Smart Charger + 100A Relay which is a bit pricey so I went for my Homebrew "HR30/120" system instead ....
30A Smart B2B Charger + 120A Victron Cyrix-CT Battery Combiner with auto-switching based on Battery State of Charge![]()
If you’re on about the bending tool you need the machine to drive it. You’re welcome to use the machine if you’re in our area.Never seen one of those before,any chance of buying one.![]()
Some do work, but it’s normally too late when you find it doesn’t.Should have used a 2 pack zinc rich epoxy,there is no longer any lead in paint,its a con,sorry to say
Found this “You're thinking of Red LEAD paint Trev. the man is using Red OXIDE paint, which you
can get even in Halfords, a benign paint as far as paints go regarding H&S.
Found this “
Red oxide, also called red lead, reacts with iron and iron oxides to form insoluble compounds called plumbates, in which lead is part of the anion, (PbO?)?². For instance, ferrous plumbate has the formula Fe(PbO?), in which the cation is Fe?².
Halfords must have a red oxide using different materials.
True but its cr-p,2 pack zink rich epoxy every time,remember i was in the anti corrosive biz.You're thinking of Red LEAD paint Trev. the man is using Red OXIDE paint, which you
