I have two Lenovos, one running Windows 10 and the other later model running Windows 11, I have never had a problem with either, I also have two Microsoft Surface laptops both running Windows 11, they are excellent as David said, I bought them for the touchscreen capabilities but rarely use them with that, the only disadvantage is that it is a PITA to fit bigger harddrives in, I have never tried Linux, I have heard it makes you paranoid
when I started a new job back in 2001, got given a
Dell to use and it was fine, but I did find it was not very robust and the hinges started to crack. the next machine was an
IBM Thinkpad (before IBM got out the PC game and sold off the business entirely to Lenovo) and that was far superior (IMO). Obviously it was a newer machine, but the overall build was better. It was not without its flaws and faults, but I liked it. (we used these laptops as proper portables, travelling around with them so they needed to be robust).
When I had to buy a laptop for myself I went for an
HP Convertible and that was pretty good and worked well, and I got a new
HP x360 one a few years later (actually be 6 years ago next month). Got a pair of them and started off ok but the
battery life became shocking on both
one of the laptops failed before I got round to swapping the
battery. the other I did replace the
battery and that sorted it for another year of so but then it crapped out again and only lasts 5 minutes tops. That and the very loud fan noise meant time for something else as fed up repairing it - not HP again and not Dell (for personal reasons, not technological ones). Replaced the first failed HP with a
Lenovo Thinkpad. I chose one where you could easily swap or add a
battery to it but it has been fine. Was a used one to start with, but been fine for last two years. Replaced the second HP with a
MS Surface machine. Only had this 2 months (but was used) and I would say nicest machine I have had. The build quality is way better than any other machine I have had (as it should be considering the prices of these things when new). Case is aluminium rather than plastic and has zero flex if you pick it up from a corner.
(Oh, and also gone through a few Netbooks with 10" screens before Tablets became a thing. Had a
Sony Picturebook, a couple of different Sam
sung Netbooks and a
Lenovo Netbook, all running various flavours of Windows. They all did their thing ok - terribly slow compared to modern machines and a current Tablet is a better option for most I would say).
Downside of the Surface machines - and especially the Surface Book 2 I have - is servicability is terrible compared to other brands. It is strongly recommended that buyers of the Surface machines make sure they get the spec they need up front as upgrades are really not feasible. My Surface Book 2 has the whole computer built into the screen section (like the surface Go and Pro I think?) - it is in many ways a Tablet, but in the case of the Book, with an detachable keyboard dock (My first HP laptop was the same actually )- got a keyboard, a 2nd
battery and some ports in the base but can seperate the screen entirely from the base as opposed to rotating it 360 degrees.
But despite the lack of servicability (which as a hardware engineer guy, really goes against the grain to like), I love it - but if it goes wrong, I can't fix it
What I have done is fitted a memory card as a permanent thing and will save & sync my files to the memory card rather than just on the hard drive (actually an SSD) so if the machine won't start one day, I can easily access what I want without having to disassemble the computer. Used this same method on the HP and found it worked well. I would strongly recommend to anyone who uses a computer to think what happens when their computer stops working - how do they get important data off it? important to prepare a plan before it is needed
