marchie
I suspect this subject may have arisen before and that there may have been a variety of opinions, but here goes ...
The Van is in for MOT today and I suspect that there will be an advisory for the tyres, on age grounds [2016 Reg on original tyres]. Present tyres are Michelin Agilis with M&S markings, but they do give a quite harsh ride at the recommended 80psi. I'm thinking of changing to Continental 4 Seasons or similar, but I'm not sure if these will have the '3 Peaks' label. I'd rather avoid the faff of a set of Winter Tyres and a separate Summer set, not least because of storage problems.
We have a 5.99m Burstner Ixeo 590 [3500kg GVW] and the [almost empty] loads on the axles and individual wheels when we bought the Van were:
Front 1 660kg Front 2 625kg = Front Axle 1285kg Max Load 1850kg
Rear 3 769kg Rear 4 772kg = Rear Axle 1541kg Max Load 2000kg
Most kit has been weighed individually, and, if we travel with 2 passengers, full water tank, full diesel and full gas, and all the clothes, food and furniture for a long stay, the payload is around 615kg, against an available 706kg, so some 90kg spare capacity, after allowing for 2 standard bikes weighing 38kg on the rear rack. In practice, we'll travel with a maximum of 60 Ltrs of Fresh Water, not least because a full tank does make the driving heavy going [in terms of pedestrian performance, rather than adverse handling], so we should have closer to 150kg spare payload
All/any thoughts and opinions will be welcomed with open arms!
