Project Camper
Having taken the old pump apart, it appears there are no cracks in the pump housing and water was escaping from between the two halves of it. Today's job, because its raining, will be to clean up and reassemble the pump with a smear of Hermatite on the surfaces, then I'll have a spare. The existing pump was manufactured in 2014.Changed the Shurflo pump because it leaked from the diaphragm assembly while we were at Barnoldswick. Not a big job, just the usual requirement to be a double jointed bugger, which I aint.
Cheers
H
That looks really smart and functional, David. My Satnav uses the Garmin sticky pad to attach to the redundant internal rear view mirror, but the lead dangling down the screen to the power socket is distracting and unsightly. I'll probably add this to my pending order with you! Just waiting on Fridge Door parts availability clarification at present, but hoping that the local Dometic Agent has the crucial security lock 'kicking around somewhere' [his words]. Hoping to find out on MondayDid a little job today that was a "get round to it" for coming up for a year!
Moved the Sat-Nav/Reversing Camera Monitor to the top of the Windscreen last year and ran a cable via the ceiling to the TV pod area to avoid hanging down cables. No ignition control signal up there, so the Sat-Nav was always on and had to physically unplug it or remember to switch off round the back.
So today fitted a little switch to turn it off remotely (blue switch on side below). Advantage of that is it removes power to the Garmin Plug with transmitter so should save an extra little bit of power as well
Yup clean sweep neilDoes stripping my Dyson V6 down and cleaning it all out count? It certainly works a lot better now and is quieter
