Exwindsurfer
It's not the battery Del it's the glow plugs sorry to say.Be careful when replacing it, if you have too. My back still gives me little reminders.
Don't forget Alpha Batteries do a great deal![]()
The time to worry, Jeff, is when the Van's glow plugs are brighter than those between one's earholes; and I'm approaching that point at speed! My former boss used to describe colleagues as being 'as bright as a glow worm's armpit', and I used to laugh. I'm not laughing now!Steve it's my glow plugs mate the battery was lashing it over no bother .
be careful Jeff, Chris may fit one to you to preheat your engineI've got one of theses I am going to fit into the water system of the engine s9 I can plug it into the mains and pree heat the engine .View attachment 65634
I knowOuch!
be careful Jeff, Chris may fit one to you to preheat your engine![]()
They are known to snap in the head .As Trotter said earlierOuch
No need Terry I am always up to temp (wink wink ) lolololbe careful Jeff, Chris may fit one to you to preheat your engine![]()
Recommendation I believe is to get the engine hot before attempting to remove the glow plugs.They are known to snap in the head .
Thanks EricRecommendation I believe is to get the engine hot before attempting to remove the glow plugs.
step ladder inside and pop up from the roof vent?Turned Brunhilde around so that I could reach the base of the roof slope where water gathers, and cleaned the muck and detritus off. Balancing a 5 litre container on top of the stepladder was a bit hairy; managed to wash my jeans and shoes at the same time ...
Is this another fetish o yours terry ,bea must be up the wall wi youI put on wet suit boots (rubber soles) then up onto roof and hit it with pressure washer.
