You realise Wully will be after a set now, obviously in some royal tartan.😅
after i poured a pot of chilli over them at new year christine will need a new set luckily it was before i’d had a drink lol
I heard it cost you a few drinks ! 😂
being with christina always costs a few drinks but she’s lovely as for the other one !!!
Sorted new thermostat , just for your info I read thermostat can be affected by dust and may need cleaning ??? As we say in Sheffield bang a nuen on ,
Got to agree. After all the buggering about that I had,I wish I’d known about that particular wrinkle beforehand.
Cheers
H
Took Brunhilde for a 28 mile drive to get the engine thoroughly warm and to get some worthwhile topping up of the Vehicle Battery[ 'VB]. Yuasa say that the VB won't charge at a high enough voltage just from solar/trickle charge et al, and that the Battery will degrade quicker if it's not recharged to about 14v regularly. So, that's my duty done, and my parking space was still free when I got back!
3 to 4 hours they said.....aye right!
Both weld nuts broke loose trying to remove the bump stops. Managed to slide a wedge inside the tunnel to hold the nut whilst undoing the cup for the bumpstop. Next task was to fit the bellows so wedged the centre nut on the bellow whilst holding the nut within the tunnel over the hole with my finger, presenting the bolt through the hole balancing the bellow on one hand and then trying to spin the nut with my finger in a blind hole. Was determined to get both done tonight so now a well deserved pint. 20230120_164423.jpg20230120_160111.jpg
May I add lying under the van without a ramp not a good idea, fire was on and an offcut of carpet to lie on but still frozen.
Sam did you check and read the instructions properly because I think you have got them the wrong way round there’s a tiny L for the left and a R for the right on the bottom that you won’t see now that you fitted them I’d take them back off and check if I were you.
Up yer erse sun! 👆
when i had the bellows fitted on mine there was a steel anchor plate for the seat belt that fouled the bellows when squashed it was that close i had to take it of secured by 12 long bolts through floor, bolt heads under boiler took them off cut away some clearance of the plate & refitted about 2 days graft
The only thing I have had to cut was the excess threaded area on the link arm this was in the instruction book to remove, it also shows position to move the hand brake cable but there is no way there is enough excess to move and attach to the bracket supplied, I shall check again when I have the wheels on the ground.
Spent most of my time this afternoon deciding where switches and compressor will go, thought it best to site them first before running the air lines. Suggestion in the book along with brackets to locate the compressor under the drivers seat but a no go as that's where the leisure battery is. Finally decided the foot well is the best place as there is no door that side. Then thought i could put the switches and guages into a cover I was going to make up for the footwell instead of removing the switches for the mirrors as there were a lot of wires, must be getting old as finding it difficult to make snap decisions nowadays. 🙃 Revrted back to the original idea mounting the guages on the dash.20230117_111632.jpg20230121_145629.jpg20230121_172806.jpg
Na beer was calling loudly. I still have routes to tidy up and mount the compressor. I'll run the air hose along the hand brake cable from where it mounts solid to the chassis that will keep them out of harms way and then take into the cabin through the grommet where the hand brake cable enters, the compressor is just below the handbrake. I have the wire harness connected up ready to go.
I moved ours in preparation for filling it with our crap and water, I brought the hose into the conservatory to thaw out, t'were a bugger to coil up, ends together of course.
I hope the weather is kind to us, I don't do cold but for a base model Swifty it seems t be fairly easy to warm up.
