Greengrass
I am reading this as a post about fixing a multimeter and not a charger at this stage?Not much, I only opened the door to get my old multimeter out, I have a Parkside charger that stopped working I have a another of a different type so need to look at that too.
Quite pleased with myself as I diagnosed that it was the PCB mounted fuse which had blown, I've never used it for much more than checking volts or continuity before.
I just need to find someone local to supply and fit the fuse,
I'm rubbish at soldering, I need to check the charger for the other one and get both done if it's the same problem, I keep one in the van just in case.
