I am also prepared to throw in a free cup of tea (or coffee) for anyone collectingRight, pack it in David before I'm forced to make a trip to Kelso.
I did mean to update this I got two x 280 amp batteries for the price of £ 620. Inc vat .Brand new.The latest. On the eco worthy batteries seems Ian has managed to get a lot of orders and now eco worthy are sorting out a deal for him
The bulk of the batteries being 280 Amp .
Must collect from the warehouse is one of the conditions .
Should know today or tomorrow on a final price ..for each one .
That's pretty cheap! I've considered doing similar but couldn't find the cells at the right price and would be wary of parting with £800 direct to China so I take my hat off to you!My DIY LFP pack uses 304ah cells. Buying eight cells and BMS direct from China costs about £800. As four cells in series are required for a 12v system this provides 608ah (~£1.35/ah).
Weight - very light, 44kg (~ 13ah/kg)
Space - These eight cells take up the same space as two 12v 90ah batteries so very compact.
Usable capacity without rapid degradation - ~ 90-95% (~ £1.50/ah)
Charge/discharge efficiency ~ 95%Capability to cope with high loads - very good
Battery life - 15yrs+ assuming good BMS protection. Unless heavily used cycle life limits unlikely to be reached.
in this instance presumably as well put together as all their more expensive battery. Its got the Fogstar name on it and they have commissioned them so...Lithiums have very much become a commodity product. Just buy a bunch of cells and a cheap BMS and all you need is a pre-made case to stick them in and voilá ... got a Lithium Battery.
How well is it screwed together though?
motorhomer.com
This was my 4th purchase from China direct. Previously spending between £3.5k and £4k on 32 cells each time for three 30kwh off-grid packs. No issues but plan ahead as delivery typically takes at least 8 weeks. I test each cell for capacity. Using a well respected retailer usually provides better actual Ah figures. This order resulted in all cells exceeding spec (305.4 - 309.2 Ah).That's pretty cheap! I've considered doing similar but couldn't find the cells at the right price and would be wary of parting with £800 direct to China so I take my hat off to you!
Out of interest what's the spec on your chosen BMS?
Yeh, I've watched quite a few of his videos, I like his approach and the way he tells it like it is, if he cut out the pointless waffle he'd be perfect but he's far from alone in pointless waffling, in fact many are worseThis was my 4th purchase from China direct. Previously spending between £3.5k and £4k on 32 cells each time for three 30kwh off-grid packs. No issues but plan ahead as delivery typically takes at least 8 weeks. I test each cell for capacity. Using a well respected retailer usually provides better actual Ah figures. This order resulted in all cells exceeding spec (305.4 - 309.2 Ah).
The BMS is a JK 200A (4S-8S) with 2A balancing. I used the 16S version for all my 48v off-grid systems. I think that they are the best. View 'Andy's Off-grid Garage' YouTube channel for a masterclass.
I find it very hard to watch Andy. He waffles on and verges off-track even more than I would - and I wouldn't watch myself on YouTubeYeh, I've watched quite a few of his videos, I like his approach and the way he tells it like it is, if he cut out the pointless waffle he'd be perfect but he's far from alone in pointless waffling, in fact many are worse
With that BMS capable of both do you use 24v in the van or did you stick with 12?
New member here and sort have come here (late) from a mix if an interest in off grid, Campervans (I've had a couple years ago and possibly helping a mate with the electrics on his) and recently helping an elderly guy sort the electrics on his 70' Narrowboat, including replacing the batteries (4 x 12V / 120AH FLA in this case). Repacing the partially connected 100A shunt with a Victon 250A Smart Shunt with everything going though it helped us prove the batteries were shot. It might also help him preserve the new batteries as he can now see the charging current via the app and ensure good absorption stage / tail current etc. Going lithium would save some diesel, running a 50hp diesel engine just a few amps of tail ... ;-(I see a lot of folk getting Lithium for their boats, but very often they are adding Lithium to their existing Lead setups and not switching (there are very good reasons not to go full Lithium on a boat).
Tend to be narrowboats where there is no point removing the lead batteries - especially if they still work - as if you did, you would only have to go and buy some bricks to put in their place to provide the ballast, but also seeing boats with Lead and Lithium combos - got Adriatic cruisers and Greek yachts with that setup (one added 4 x Fogstar Drift 480ah batteries to join the existing Lead Bank).
I was trying to remember how long we have had our Relions, so it was 5 years and there still going strong, mine are in a polystyrene lined box in the living area, so no real probs with the cold.I've had unheated lithium batteries for over 5 years now and never had a prob within and yes we do use the van in the winter.The batteries are set so they won't take a charge below -2 but we can still use them.
Mine are under the seat with vents for the living areaI was trying to remember how long we have had our Relions, so it was 5 years and there still going strong, mine are in a polystyrene lined box in the living area, so no real probs with the cold.![]()
Hi i purchased a 280ah lithium battery from eco-worthy & an inverter changed from two lead batteries, ive got two victron solar chargers connected to two solar panels,( combined 330 watts ) the battery is bluetooth so you can check this anytime, hope this helpsHas anyone come across this company (https://uk.eco-worthy.com/) They are marketing solar and lithium products for campervans. They appear to be significantly cheaper than anything else I've come across (280Ah - £549.99). I'd be grateful for any insights you might have out there.
Thanks.
Richard
