Scotia
Tell the truth, ye have been thrown oot!Just turned gas on and fired up heating nice n snug warm as a bug think I might sleep in it the night![]()
I was going to suggest changing the air filter but ye have had that done.Got Moho back from getting engine serviced. It suffered from diesel smoke higher up in revs, was meant to have been serviced before I bought it by dealership but was just oil change, so got the local garage to run a fuel system cleaner, eng oil flush , change all filters and eng oil, turns out fuel and air filt were dirty. Now it pulls really well with no smoke, happy days - couldn't be bothered doing it myself.
I used clear waxoil and only ever had to do it once. The mot station said it was no problem as they can still see if there are any pipe oil leaks for the break system.Gave the chassis a good oiling.
I've an auld singer sowing machine in the workshop.today went to a local clearance warehouse and got 4 rolls of off cuts all the same upholstery/curtain type material hope to make slip covers for the seats to keep maeve of the furniture, it wasn’t bad a total of 40m2 in 4 rolls for £10 the two bench side ones are easy enough but the wrap around is 6 seperate cushions i’ll have to learn to use a sewing machine lolView attachment 74653
Down on the right it where the wee spool goes to load it up, put the tread into the slot and that weaves back and fourth loading the spool which then fits into the shuttle. Draw the thread forward then return back to the centre. The shuttle is housed under the chrome cover down by the needle.i have my mums auld singer in a cabinet just like this she had it for her 21st birthday so that would have been 1942 had it adapted from the treadle with an electric motor all there just not got a clue how to use it it’s got the catalogue and the tool kit with it but the walnut veneer on the fold out table is a mess it unscrews so i could send it off to be repaired some time View attachment 74654
