I'm going to ring my mechanic in the morning first, then maybe rescue on Tuesday depending on what he thinks.
i would try removing the ground from the battery for a while.One tip was key on for ten minutes just trying that.
My Neighbour had this issue in her 2010 Ducato. Drove into town 5 miles to a car parts place. back into her van and wouldn't start. had the padlock symbol on the dash. tried spare key, no good. got a mobile guy out who reprogrammed the keys or something and sorted it out. Think it cost her around £120? this was last year.I'll try that tomorrow, then recovery if it doesn't work.
I'm not sure but I don't think he did clear them.5 different error codes? interesting. be interesting to know what the actual problem is.
Did the guy try and clear the codes and then try starting to see what codes then came up? some may be due to your battery dead issue which is no longer a factor.
Yes I did try that Allan, I left it about 30 minutes while I wrapped some of my gear away, I tried the spare key too, just ringing the breakdown company to find out if he did or not.Now that your battery seems to have some charge in it, still think it's worth disconnecting the cable from the negative post as suggested by David earlier. Leave it a good ten minutes then try again, ECU modules are fussy things and don't like interrupted boot ups which may have happened during the previous attempts to get started.
I had a very odd thing happen with my van some time back... all normal, then put some fuel in and I got a phone call so I parked up and turned the engine off. 20ish minutes later went to restart and nothing. Limited lights on dash but soon as I tried to start, all lights off and nothing.Now that your battery seems to have some charge in it, still think it's worth disconnecting the cable from the negative post as suggested by David earlier. Leave it a good ten minutes then try again, ECU modules are fussy things and don't like interrupted boot ups which may have happened during the previous attempts to get started.
I don't think you are one to get ripped of, Kev, but make sure they just don't throw parts at it willy-nilly. e.g. manual says P0200 = Requires New Fuel injection ECU (for example), so they just fit a new ECU because that is what it says.Yes I did try that Allan, I left it about 30 minutes while I wrapped some of my gear away, I tried the spare key too, just ringing the breakdown company to find out if he did or not.
no ideal.No, he didn't ffs.
