Hi all. Well well batt readings. Off veh on bench in garage not connected. 10 am yesterday. 13.34 And 13.27. 11am 13.17 and13.14. 5pm 13.02 and 13.05. Today 10am. 12.9. and 12.8. Well I read that as both batts are loosing there charge, So now what. Put them on charge 24hrs check again. Or accept they are loosing. If I put them back in veh. Connect up. Switch eng on take readings (((aaah that's what you said to do before disconnecting. ))) will this then show charging side is right. Cheers.
Wrong!!!
You didn't follow the precise instruction did you!!
I knew you wouldn't
You will always get a slight loss of power through normal
battery drain. Looking at the readings at this moment the batteries are still stabilising / leveling out. Leave them on the bench for another 24 hours, AT LEAST, test at 10am tomorrow, if you cant test at 10 am tomorrow and can only test after you come home from work test at 6 or 7 pm, if you're going to test in the evening on Monday do the same on Tuesday 24hrs after Mondays test. BUT ALSO TAKE A TEST AT 6 or 7 tonight if doing this option.
This is a long slow test and as I said earlier it is not my favourite, I might do this test myself, if I was really, really, really, really bored. Well I have and it didn't prove anything much. But I said most of this in the earlier posts.
You really need the £20 tester that I have, I was playing with that yesterday, I have 2 x starter batteries, well I have 5 all together. They are all knackered,
in effect, as an individual unit. So they wont give out the rated 850amps cca and fail the test, but to me that doesn't mean they are past all possible use, (it used to when I was selling batteries to truck owners, when trucks left the depot a 5 in the morning or drove to Scotland or Russia, and if they have to call out a recovery it cost them £1-2 000.00). 2 of my batteries will give out 600amps cca, they were charged and left for a couple of months and then tested. Individually they will both start the MH on all but the coldest days. Now if I fit those two batteries together on the MH I go up to 1200amps cca, better than a new one at 850cca. I have already proved that they hold their charge over the 2 month sitting on the bench. The tester can be adjusted so I can test anything from, (I think 2000cca down to 40cca), it doesn't put a drain on the
battery to flatten them, so I can start off at 850cca and work down in units of 5, but I just did it in units of 100 at a time, 3 x tests, say 3 mins total time on 2 batteries I've got all the information that I need. You should get one, in fact everyone should.
Don't do any other test at the moment and just follow the instructions, for the moment. You can do other tests later. Ahhh, Folkestone to far to meet.
