Lord Lucan
Fitted curtain rails all round the rear windows and across back of cab. Just need curtains now.
Also, fitted dash cams front @ rear.
If you need a quick solution, have a look at this - https://amzn.to/2WOG99rBroke a cupboard door lock. The button presses in but stayed in. Tried silicone oil and it with a knife. No good. Googled solutions, but no alternative suggested. So had to force the lock and break it. I was desperate. The coffee was inside!
Now need to work out how to stop the door opening and spilling its contents whilst in transit!
I have had both knees replaced in the past 3 years and prior to the first op have been driving automatics. If you're not yet into them then I strongly suggest you have a think about it when ordering your next MH. Best of luck with the op and the strongest advice I can give is to prep by building up the quad muscles beforehand and ensure you follow (to the letter) the physio excercises. It worked for me and had no problems at all - you should see me go up and down stairs nowadays!Started stripping everything out my pvc in preparation for when I part ex it in a month or two when able to drive after my upcoming knee replacement.
Now emptied, amazing the amount of tinned food I had onboard. Now just needs a good clean inside and out and a scratch to hopefully remove from offside hab window.
Will hopefully get it done this week as fingers crossed I get a cancellation and get the op done early.
Agree regarding the physio after op, followed it to the letter last September after left knee replacement and the physio department were well impressed with my progress and signed me off after 4 weeks.I have had both knees replaced in the past 3 years and prior to the first op have been driving automatics. If you're not yet into them then I strongly suggest you have a think about it when ordering your next MH. Best of luck with the op and the strongest advice I can give is to prep by building up the quad muscles beforehand and ensure you follow (to the letter) the physio excercises. It worked for me and had no problems at all - you should see me go up and down stairs nowadays!
Thanks David. Our problem is that being on the move is lack of a postal address. Heading to a dealer this morning. But if that no good, will look for something similar in a diy store.If you need a quick solution, have a look at this - https://amzn.to/2WOG99r
No need for any holes, etc, so could be a good temporary option? (I use these on my cupboards as standard and pretty good I find)
Trawling the internet at present looking at what’s about.No pre reg or cancelled orders on the go steve ,have you thought about Germany?
