Yes, I worked in Edinburgh for a year and loved it.
If you are referring to changing the oil filter, MMM chief boss mechanic bloke says just buy the whole assembly from Fiat. It is virtually impossible to replace just the filter without incurring leaks. Why, I dunno, I've never had one of those.
If you are referring to the Robotised Gearchange system I can only say I have heard lots of reports about the difficulty of getting them worked on: apparently setting them up can only be done by a Fiat franchised dealer, and a competent one at that, which you have to search for. They have to be connected to the Fiat factory computer and it is an expensive process - I seem to remember £700 for changing the fluid and resetting the clutch system. That's without the cost of fitting a new clutch. When I was looking for a replacement motorhome recently I -let's say - avoided them. I was advised by an independent garage to get a proper torque converter automatic, and he only recommended Mercedes, although someone said that the current Ford Transits have a torque converter - and I believe that VW does now as well - although if that is their DSG gearbox I don't think it has a torque converter. That DSG is lovely, when it works. I had a Golf with it, and it was indeed lovely. I then looked at youtubes of how to service one, and it's a big job, again many hundreds of pounds. The Mercedes on the other hand just needs the ATF draining from the box and torque converter, and a new filter fitted. This is an hour's work because the gbox sump has to be removed (about ten bolts) to change the filter. I have done it many times on MB cars and it really is a DIY job.
