Landyseverywhere
Some people have too much time on their handsTook the wheels off and moved them around to get all the fiat badges level for the summer. Note to self try not to wheelspin.View attachment 72240
Same hereWe are awaiting collection of our new to us vline..but its like Christmas every day, parcels arrive with new things for it.
And, dont keep us in suspenders.Took the van for mot today
So the back hander worked then Gordon lolololPass
Try a box key or twist the tap.Tried to remove the kitchen tap to silicone grease the ceramic faces and cure the slight weep. Unfortunately, someone has screwed the rubber/plastic 28mm'ish nut that holds the cartridge in situ just below the surface of the tap body, so cannot grip the nut faces to get the cartridge out ...
Haven't got anything remotely near the size with me, and the Chinese Shop + Ferreteria haven't anything in stock! The tap is just weeping at present, so will push on to Benicarlo tomorrow in the hope that Tambo Motorhomes will have a new cartridge/tap in stock and that Ramon can fit us in on MondayTry a box key or twist the tap.
Wrap a cloth around it .Haven't got anything remotely near the size with me, and the Chinese Shop + Ferreteria haven't anything in stock! The tap is just weeping at present, so will push on to Benicarlo tomorrow in the hope that Tambo Motorhomes will have a new cartridge/tap in stock and that Ramon can fit us in on Monday
Already done that as a temporary measure. I'm hoping to get a proper repair done asap so that we can use the Van fully. A 5.99m unit needs to work properly to make the other compromises acceptable, and we're already 'carrying' the Burstner delaminated floor until it can be repaired in December 2024, 19 months after the fault was discovered and reported ...Wrap a cloth around it .
Steve get some tredaire underlay and you won't notice it ,like walking on airAlready done that as a temporary measure. I'm hoping to get a proper repair done asap so that we can use the Van fully. A 5.99m unit needs to work properly to make the other compromises acceptable, and we're already 'carrying' the Burstner delaminated floor until it can be repaired in December 2024, 19 months after the fault was discovered and reported ...
