I’ve tried to replace our window blind! So tricky to finish off...
We took the rear door panel to the dealer a few weeks ago (CV-3wks), after ordering a replacement blind/fly-screen at their parts desk, but when it arrived 2 weeks later it was found by them to be too large. By this time CV had closed up the premises, so I started looking on eBay for something suitable, and found one off a caravan breakers firm for £15 + £10 postage, and ordered it.
it arrived several days ago, and soon we realised it was a different fit to the original; it was meant to fit direct to the rear door (Fiat Ducato), rather than the panel which would now have to surround the recessed blind instead. (Following?)
So we enlarged the hole in the panel and stuck back the carpet material to look nice, but now comes the tricky bit - drilling a hole into the recessed door which is covered with insulation and more carpet, making it all very spongy.
There are two screws each side at the top, and the screws need to be fitted, first thru the thin fragile little plastic tab holes very precisely with millimetres accuracy. And there is a fragile tab at the bottom of each side frame too. They are so risky I daren’t attempt it! A screw would need to be drilled into place in the door skin, and then removed before placing the blind frame in place and then re-screwing the screw gently till it touches the plastic hole surround on the frame. Not too tight to crush the plastic surround!
if a error is made, the whole thing is ruined. I really need someone with experience to do this for me. Sadly the dealer is the only option, and they’d need the van and door panel and blind frame on site. Not a job I can do today after all!
