Deleted member 2459
Sorted, with delight, after a little nudging from the Mrs to just try and do it!
I cut through some of the door insulation under the window to find a ‘wooden’ support there for the window - it turned out to be hardboard over some white foam insulation, but it was enough to screw a batten to for the lower blind fixings. Up top was nowhere, in fact it was curved metal of the door where it recessed for the window, so here the decision was to fix the blind to the panel instead. This meant gluing a thin plywood board across the aperture in the door panel so that the screws could be inserted into the board there. The blind ended up being fastened to the door at the top, and to the door panel at the bottom! The bottom needed to be inserted further into the door, than flush, because when closed, the frame would have bumped into the kitchen worktop surface - not enough space!
So it’s done! And the excess carpeting behind the blind has tucked in nicely closing up the space between the door and panel. With bikes on the door we shall have to be as gentle as possible when closing properly in future.
Thanks for the ideas and suggestions.
