maingate Full Member Messages 1,040 Today at 1:31 PM #21 You can extend the range by fitting a large diesel generator in one of the lockers.
Geek Full Member Messages 825 Today at 1:36 PM #22 Pudsey Bear said: Charging bays are already being used by motorhomes. Click to expand... Assuming a standard "fast charge" of 22KW peak (18KW average), if it was discharged to 10%, it would take over nine hours to recharge. You'd need a faster charger, which usually costs more KWh.
Geek Full Member Messages 825 Today at 1:37 PM #23 maingate said: You can extend the range by fitting a large diesel generator in one of the lockers. Click to expand... A diesel generator that fitted in a locker will probably only be 2 to 3 KW, so it'd be running 24 hours a day to catch up.
maingate Full Member Messages 1,040 Today at 2:13 PM #24 Geek said: A diesel generator that fitted in a locker will probably only be 2 to 3 KW, so it'd be running 24 hours a day to catch up. Click to expand... But...... it would still extend the range. Maybe only by about half a mile but I am not wrong, am I?
Geek Full Member Messages 825 Today at 2:29 PM #25 I'm not sure how much the range would be reduced by the extra load of a generator. Might end up with less range as well as less payload.
maingate Full Member Messages 1,040 Today at 3:08 PM #26 Geek said: I'm not sure how much the range would be reduced by the extra load of a generator. Might end up with less range as well as less payload. Click to expand... Just in case you missed it, I was not being serious. I's called a joke.
