Exwindsurfer
What will you be pointing at?Well got back from wales today and fitted. The pointing puck antenna + drilled hole in roof and fitted new waterproof box and fed the cable inside all ready to connect up View attachment 59372View attachment 59373
Set out to replace the habitation step warning buzzer and after trying to find out online where it is located I saw several posts relating to the earth wire on the micro switch being corroded. Under the van I went to check out, sure enough it was white so bored out the rivet but had to remove the outer casing to reattach the earth wire, phew. When I was undoing the casing I noticed the pinion shaft that operates the arm to push the step out and in was squint, when I finally managed to free the cover I noticed that the servo housing was cracked where the pinion gears are housed. Geezo.
The step always had a droop in the time I have had it which I had put down to wear but on further inspection when weight is put on the step the pinion is pushed sideways due to the broken casing. To resolve this I have bored through the outed casing and tapped the mating side, I now have a 6mm Allen bolt through the step through the outer casing and threaded into the end cover. I now have a firm step but still no warning light and still have not managed to located the buzzer.![]()
Thank you, only problem is I have not resolver tge problem I originally set out to achieve.nice bit o work sam![]()
Patience and you will get there samThank you, only problem is I have not resolver tge problem I originally set out to achieve.![]()
As I mentioned earlier in this thread, the step on my van isn't electric so I don't have any experience of fixing them, but I was under the impression that they automatically retract when the ignition is turned on. I suppose it must vary depending on the manufacturer. Anyway, if you need to fix the buzzer it might be easier simply to fit another one in your preferred location rather than trying to track down the existing oneSet out to replace the habitation step warning buzzer and after trying to find out online where it is located I saw several posts relating to the earth wire on the micro switch being corroded. Under the van I went to check out, sure enough it was white so bored out the rivet but had to remove the outer casing to reattach the earth wire, phew. When I was undoing the casing I noticed the pinion shaft that operates the arm to push the step out and in was squint, when I finally managed to free the cover I noticed that the servo housing was cracked where the pinion gears are housed. Geezo.
The step always had a droop in the time I have had it which I had put down to wear but on further inspection when weight is put on the step the pinion is pushed sideways due to the broken casing. To resolve this I have bored through the outed casing and tapped the mating side, I now have a 6mm Allen bolt through the step through the outer casing and threaded into the end cover. I now have a firm step but still no warning light and still have not managed to located the buzzer.View attachment 59381View attachment 59382View attachment 59383View attachment 59384
Not this one a Burstner 747 but there is a micro switch that is pressed when the step retracts and trying to trace the wires is a nightmare, by the time I had fixed the motor mount I ended up doing other work to try and free some time up during this week to sort out the handbrake.As I mentioned earlier in this thread, the step on my van isn't electric so I don't have any experience of fixing them, but I was under the impression that they automatically retract when the ignition is turned on. I suppose it must vary depending on the manufacturer. Anyway, if you need to fix the buzzer it might be easier simply to fit another one in your preferred location rather than trying to track down the existing one
Thank you xIt looks fab well done .
